fuel cut defender
Old Jul 28, 2004 | 10:35 PM
cuscoWRX's Avatar
Question fuel cut defender
i was thinking of putting a turboXS fuel cut defender on my WRX, but i dont know how safe is it to boost 19psi on a stock turbo, what would you guys recomend me to do, put the fuel cut by it self or put something else in combination with the fuel cut to be safe.
Old Jul 28, 2004 | 10:42 PM
None of the above. 19 psi is about 2.5 too much for a stock turbo.
Old Jul 28, 2004 | 11:01 PM
ish's Avatar
ish
yeah there isn't any benefit over 17 psi on the stock turbo
Old Aug 6, 2004 | 10:36 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
you don't want to run more than ~15psi on the stock ECU. If you run aftermarket boost control, you should also be very careful of part throttle full boost.
BTW, you can run the stock turbo at 19psi in the midrange just fine if you tune it and run some higher octane gas.
-- Ed
truWRXtacy
Jan 2, 2006 11:54 AM
DAMOTORSPORT
Apr 4, 2004 12:31 AM
pacobeagle
Jun 16, 2003 03:10 AM
NotoriousWRX
Apr 8, 2003 11:59 PM
slvrwrx02
Dec 26, 2002 01:09 PM
Top
