engine management for '04 WRX and turbo upgrade (was:PLS hELP? NEWBIE IN THE FORUM)
Old Mar 20, 2006 | 08:01 PM
Lazyboy's Avatar
Car Info: 2004 wrx impreza
PLS hELP? NEWBIE IN THE FORUM>>
Just wanted to ask around about modifying a 04 wrx. see, i recently got a STI turbo installed in my wrx 04 impreza and wanted to know what the next step and any advices in what to do next.? In terms of engine management, hp gain, and etc...
thanks
tristan
ps: anyone know where I can get STI injectors (preferably the pink ones) for a cheap?
Old Mar 21, 2006 | 01:19 AM
FULLSPECTRUM's Avatar
Car Info: 2005 OBP WRX STI
wow. . . best place to get STI Pinks are through the classifieds sections here on I-club. . .
- Food for thought:
Conduct a search before you ask questions. . .almost 98% of the time you will find your answer. but to help you out a bit. . .
You got your turbo, get your pinks, a fuel pump. . . up/down pipe. . . maybe a COBB AP and tuning. . .
- Mark
Old Mar 21, 2006 | 09:50 AM
Lazyboy's Avatar
hello again
thanks for the advice.. the thing is, this is my first time in any forums. i had gotten a downpipe, up-pipe, and exhaust. Then i just decided to go for a better turbo. Those fuel pumps are mad expensive hehe.. i also have a boost controller with the turbo. Now the thing is after the fuel pump what would be the next step. Should i also get a new clutch..? and how much boost would i be able to use with the injectors installed..?
sorry for asking too much..
tristan
Old Mar 24, 2006 | 05:34 PM
turtle-speed's Avatar
Car Info: 2004sti
Ecu , your stock maps won't work well with the after market mods .
Old Mar 25, 2006 | 02:29 AM
Wingless Wonder's Avatar
I would recommend real engine management over a manual or electronic boost controller because those devices do not adjust ignition advance or fueling to compensate for different conditions and load on the engine. Currently the Cobb AccessPORT is popular.
Old Mar 25, 2006 | 12:36 PM
thricecompany's Avatar
Car Info: 2004 WRX COBB air intake, COBB short throw shift lever, #" exhaust with high flow muffler
I have a 2004 WRX and just a little info on a manuel boost controller, IT WONT WORK ON AN '04 !!! PERIOD. At least not without having any ecu work done. All I have is a COBB aior intake and a 3" pipe from the last cat and back.
Old Mar 28, 2006 | 10:11 AM
MacMan2.0's Avatar
Car Info: 04 WRX waggon ShortShift Boost Gauge
Is the turbo an IHIvf30?? theres a map for the cobbAP=320hp. it lists the proper parts for running this map..
Old Mar 28, 2006 | 02:48 PM
subie OCD's Avatar
Car Info: 04 STi
tristan
you can get them for less than $100.....!??
lburrrna
Mar 20, 2007 12:02 PM
justasking
Mar 21, 2005 10:21 AM
Jgrahn555
Apr 2, 2003 03:01 PM
i-speed
Nov 22, 2002 04:34 AM
