Cylinder #1 Misfire....
Old May 15, 2008 | 08:39 PM
solidace46's Avatar
Car Info: 2002 Subaru WRX
Unhappy Cylinder #1 Misfire....
Hey guys I was driving today(2002 wrx) and I recognized my check engine light was on, I got a diagnostics check right away for free at autozone. The code that came up was P0301, which means cylinder number 1 is misfiring. Symptoms I am experiencing are low idle, and a slight spudder when i push the clutch in when i am around 3,000 rpm's or higher.
The probable causes to that could be:
1) Ignition System Fault- spark plugs, wires, coil
2) Vacuum leak
3) Injector Faults
4) High or Low Fuel pressure
Has anyone experienced these problems or can anyone give me some advice on what I should do? Most likely tomorrow morning I am going to the Subaru dealership and am going to have them run a full diagnostics check and find out exactly what is wrong, hopefully it is only plugs and wires but I guess it could be anything... any input helps, thanks.
Old May 16, 2008 | 04:08 PM
AngrySubyWagon's Avatar
Car Info: ghey e-rights activist
more than likely its 1 or 2. check for boost leaks first. If all is secure and you're positive. check your spark plugs. post what happens.
Old May 18, 2008 | 08:29 PM
Cp3aight's Avatar
Car Info: 05 WRX wagon
Spark plugs are a great indicator of whats going on inside your cylinder. Check #1 and compare to others and see the difference, that should help you.
Old May 18, 2008 | 11:38 PM
solidace46's Avatar
I've been driving with the check engine light on for a few days now, its going to the dealer on tuesday for a tune up, and hopefully the new spark plugs will fix that problem because i heard subies eat them up cause they run so lean... not sure if its true but it makes sense. Anyways today i was driving and the light either blinked at me or turned off and back on for a second, that kinda worried me but Im gettin it fixed soon. I'll post back up when i get the results, thanks for the reply
Old May 19, 2008 | 07:39 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
How long have you had your car? did you get the 60k done? because thats when the the spark plugs are usually replaced.
Old May 25, 2008 | 12:44 AM
solidace46's Avatar
Unhappy
got new plugs...turned off the check engine light, that dept. is good now. but the turbo feels really weak from 5k-7k rpms, but from 3k-5k rpm's it pulls hard. For some reason it kinda gets shaky after i get up to 80, hate noticing these problems. The dealership said they noticed it was runnin a little lean, and they checked out my intercooler and said there was a little oil in it, which means my turbo might be ****ed up. ****ty, bought it like a month ago, but I guess im gettin to know my car...
Old May 31, 2008 | 01:59 AM
BXR_PWR's Avatar
Car Info: WRX STi 2005
I got that same code. My car acted the same maybe worse. but my mechanic found it was a pin loose inside one of the connections the coil.
kcismo
Jun 23, 2005 11:28 AM
mbquarts
Apr 19, 2005 12:01 PM
jaypowell78
Apr 8, 2005 06:45 AM
Madball
25
Mar 29, 2004 08:29 PM
my02_impreza
May 29, 2003 11:48 PM
