another question...downpipes
Old Jun 12, 2003 | 08:14 AM
SacWagon's Avatar
Car Info: 2003 SRP WRX Wagon
Re: another question...downpipes
Originally posted by fryinrice
if an uppipe is already installed, will adding a downpipe and eliminating the 2nd cat cause any check engine lights? if so, is there a way around this? Thanks in advance.
Yes and yes.
The catless DP will eventually cause a CEL. Mine ran for about 3 weeks before i got the CEL.
The fix is easy. You can purchase the resistor fix for like 10 bucks.
maybe try searching for "resistor fix" or when you order the DP, just ask the place where you buy it, they will most likely have the fix in stock.
Hope that helps
Speed Element
Engine and Drivetrain
Oct 25, 2006 11:33 AM
biznessdude
Aug 7, 2005 09:44 PM
hayakunai
Apr 9, 2005 11:02 PM
(==ImPrEzAWR==)
Feb 15, 2003 07:44 PM
