AccessPort Run Down
Old Mar 13, 2004 | 02:03 AM
fryrice's Avatar
Car Info: 04 wrx WRBlue ~v34 sold/ 05evo MR ^_^
you should order it right now since the price is 555 it's going to go up beginning of april.
Old Mar 13, 2004 | 10:43 AM
RAAZ227's Avatar
Car Info: 07 UGM STI
they are allowing you to put a deposit until it is ready to ship
Old Mar 15, 2004 | 01:15 AM
namakemono's Avatar
Car Info: gc w/ neons and a wrx that needs neons
the price is going up!?!??!?!?!?!?
do you know by how much?
Old Mar 15, 2004 | 07:43 AM
RAAZ227's Avatar
$595 +/-
Old Mar 15, 2004 | 09:15 PM
sirhankwilliams's Avatar
Car Info: 08 STI
When I ordered mine I was told that half of the cost would be charged then and the other half when the unit ships. The initial charge actually didn't go through for another few days.
Old Mar 16, 2004 | 12:52 PM
RAAZ227's Avatar
sweeeeeeeeeet!!! I cant wait!!! wooooot!
Old Mar 17, 2004 | 12:37 PM
RAAZ227's Avatar
Originally posted by oxtox
infek- I have to travel between two states quite often. Wisconsin has 93 octane and Minnesota has 92 octane. Is it correct to assume that running the '91 octane map' would be safe all of the time?
Alternatively, would it be better(or safer) to run the 91 map with 92 octane gas; and then the 93 map with 93 octane gas?
I thought some forum post said that it may not be a good idea to run the same octane map with the same octane rated fuel(ie 93 map with 93 octane gas).
Anyone care to comment?
thx, Fatty
this is the beauty of the accessport....just change the map when you change gas. p.s. i suspect the 93 octane map is for 93 octane and yes, cobb consistantly says that the best map would be lower octane when in doubt. now go get it and tear it up!
The designated number from what I understand is the minimum octane you should run. I have 93 here so I am planning on running 91 octane to be safe. But, if I were to go to the track and run race gas then I will bump it up to 93..
Old Mar 17, 2004 | 12:56 PM
iNfEk's Avatar
yup!
Old Mar 17, 2004 | 12:59 PM
RAAZ227's Avatar
Originally posted by iNfEk
yup!
See....I got the Access Port down now!
Old Mar 17, 2004 | 02:28 PM
iNfEk's Avatar
:banana:
Old Mar 18, 2004 | 01:30 AM
iNfEk's Avatar
well, when i went stage 1, 15 months ago, i went 93 octane access ecu with no probs, desirable peak boost, and a big grin. i put the gutted up pipe and stromung dp on two weeks ago in anticipation of getting the accessport (ordered 1/30/04)...so i've been running cobb stage 1.5 for two weeks and run to the door every day after work waiting for "the package." official stage 2 seems a few days away....but i still plan on running 93 octane maps (we have 93 and occasionally 94 here in pa). i don't get the "run the 91 map at 93 octane to be safe" theory...please enlighten me while i go to www.cobbtuning.com for some more backround here. thanks.
He's just a really concerned Subaru owner that wants to play it safe...!
I for one would use the 93 octane map with the 93 octane available (we don't have it here... the best we got is 92 and that's why I run the 91 octane map for safety).
Whereas if I were to run the 93 octane map on 92 that wouldn't be good.
Anyway all things aside... each map is designated at a MINIMUM rating so if you have 91 octane in your state you can run the 91/93+ octane maps... if you have 92 then you'll want to run the 91 octane map. But are fully able to run the 93 if you increase your octane with 100 octane or toluene or zylene
Jon
