AccessPORT gas mileage?
Old Apr 21, 2006 | 09:45 PM
wvinfernovw's Avatar
Car Info: 2004 wrx
ACCESSPort Gas Mileage?
Just reflashed my stock 2004 WRX to the 93 SGT 1 Map (stock car), is anyone noticed quite a bad gas mileage at first? i pushed it the first 2 days and thats all, i shift around 2500 also.
Is it just the ecu tryin to learn and settling in?
Old Apr 23, 2006 | 12:26 AM
Me&05WRX's Avatar
Car Info: 2015 STI
I'm running stage 2 and I've gained better gas mileage. I average miles per tank between 270 - 310 miles, mostly city driving and occasional highway. I've reached 310 in a tank 3 times now, and that's at the lighting of the "E" on gas gauge.
Old Apr 23, 2006 | 02:11 PM
Car Info: 2004 wrx
i do mainly city driving, would STG 1 get better MPG then Stock or Economy mode with normal driving? + i barely drive abusively
Old May 8, 2006 | 03:52 PM
EpsilonK's Avatar
Car Info: 2015 WRX
I have had my Accessport on for about three weeks or so now. I have had worse mileage. I am just on stage 1 CA (04 WRX, no real mods, just gutted intake) I was getting 26-27, driving fairly aggressive about half the time. Now, I get 20-21, driving fairly aggressively about half the time. However, I believe that if I moderate my right foot, the needle won't drop as fast.... :-P I haven't tried economy mode yet, I am going to try that on my trip home next weekend (two hour drive) I am hoping that with stg2 in a couple weeks that I will get a little better mileage, but probably not. lol.
Old May 11, 2006 | 12:58 AM
1neWRX's Avatar
Car Info: White 04 WRX
damn maybe i should get an accessport...i couldnt even get to those numbers stock with mostly city driving.
Old May 11, 2006 | 06:20 AM
Wingless Wonder's Avatar
No reflash will make a huge difference in your fuel economy. Driving habits and traffic conditions determine what you sort of gas mileage you can get in your car.
I check my gas mileage at every fillup. In heavy freeway commute traffic I average 22.5 mpg. Light freeway traffic during non-commute hours I get between 24.0 and 24.5 mpg. On 100 mile trips out of town I get between 27 and 28 mpg, with one longer trip on level ground getting me just slightly over 30 mpg when I maintained a steady speed of 60 to 65 mph. At 30 miles per gallon, I could go well over 400 miles on a single fillup but that isn't realistic unless the terrain is flat and I don't have to pass slower moving vehicles at full-throttle. It's rare when I can't get more than 300 miles from a single tank of gas, and that's well before the low fuel indicator lamp comes on.
'02 WRX, 3" catback, off-the-shelf Vishnu reflash, catless uppipe, stock turbo and turboback with two cats.
Old Jun 2, 2006 | 10:12 PM
equinn2823's Avatar
Car Info: 2006 wrx limited sedan
Talking
damn i guess i beat my rex too much because i never get over 20mpg unless i go on a road trip on the highway... guess i am boost happy..
Old Jun 3, 2006 | 09:17 AM
Chrisnonstop's Avatar
Car Info: 02 Silver WRX sedan. Eibach springs, Blitz NUR cat back, Rota 17" Attacks, Cobb AccessPort/DP
It only makes sense
That if you increase HP you're moving more air and fuel. It's only natural that milage would drop depending on how much power you gain. I don't understand how anyone has gained HP by running any power gaining aftermarket tune. My car gets somewhere in the neighborhood of about 18 to 21 MPG under normal driving conditions and about anywhere from 12 to 17 when I'm getting on it. That's running a stage 2. I'm guessing on those numbers, I haven't really done an actual test.
Old Jun 4, 2006 | 06:21 PM
Origami posted by Chrisnonstop
Why not check your mileage at each fillup of the tank? It takes only seconds at home - I check it by noting the trip odometer reading while the gas is pumping, then use a calculator to divide the miles travelled since last fillup by the number of gallons pumped at automatic shutoff (don't top off). If you buy gas using a gas credit card, the gallons pumped are noted on the printed receipt.
Old Jun 14, 2006 | 08:19 PM
gqchynaboy's Avatar
From: My lugnuts require more torque then your Honda makes
Car Info: 05 WRX
I went from 23mpg to 19mpg Can't stay off boost now =[
wu!
May 23, 2006 04:28 PM
kidatari
Sep 9, 2004 12:22 AM
Shaitiger
Wanted
Apr 6, 2003 09:31 PM
Shaitiger
Apr 2, 2003 12:09 AM
Shaitiger
Mar 30, 2003 11:22 PM
