EQ Tuning - Engine Build Packages!
Old Jul 27, 2012 | 10:52 AM
  #526
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
An STI got towed in with a blown motor that was built by another shop. Upon dis-assembly, we found one of the exhaust AVCS cam gears was installed improperly and caused the advance-return spring to break. This bent a handful of valves and destroyed a rod bearing in the process. Now we are fully rebuilding this engine the right way.
-- Ed
Old Jul 27, 2012 | 11:55 AM
  #527
04caliwrx's Avatar
-- Ed
same thing as mime!
Old Jul 28, 2012 | 09:10 AM
  #528
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Bump
Old Sep 14, 2012 | 08:33 AM
  #529
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Another couple builds picked up and another set started!
-- Ed
Old Sep 21, 2012 | 01:39 PM
  #530
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
bump
Old Sep 21, 2012 | 06:47 PM
  #531
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Bump...
All of our no-core pricing listed includes all BRAND NEW parts including case, crank, rods, pistons, bearings, etc. We never use "re-conditioned" parts unless clearly noted and discussed with the customer or if the customer provides a core.
When starting with a used case, additional steps must be taken to ensure proper oil clearance on the main bearing housings. Most used cases have been beat up enough to throw some of the clearances out of spec. We are the only shop that does an actual line hone on the main bearing housings to bring them back in spec. We also measure each oil clearance at least twice.
So don't be fooled by cheaper advertised options that take short cuts, use used parts, don't measure, and don't perform the additional machine work required for a long lasting high performance engine. When you're getting an engine built, the last thing you want to do is cut corners to save a few hundred dollars. The end result ends up being much more expensive.
-- Ed
Old Sep 23, 2012 | 06:13 PM
  #532
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
bump
Old Sep 24, 2012 | 04:10 PM
  #533
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
monday bump
Old Sep 26, 2012 | 01:07 PM
  #534
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
bump... we're not the cheapest game in town, but we always strive to be the best. We have built over 250 Subaru engines and 99% of them are running strong to date!
-- Ed
Old Oct 1, 2012 | 11:32 AM
  #535
duo's Avatar
duo
Car Info: WRB WRX 2004
-- Ed
I just dropped off my 2005 sti for an engine build. its going to be awesome. I wouldn't trust my car to anyone else but Ed and his team. Anyone looking for a quality build/install/tune is sure to be extremely satisfied with EQ tuning.
Old Oct 3, 2012 | 04:28 PM
  #536
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Your engine is now out of the car and being broken down
-- Ed
Old Oct 3, 2012 | 05:10 PM
  #537
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
bump
Old Oct 4, 2012 | 10:36 AM
  #538
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
bump
Old Oct 4, 2012 | 11:28 AM
  #539
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
JM Bump!
Old Oct 5, 2012 | 04:40 PM
  #540
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
bump
Top
