Tech Questions about Spec-C 6 speed swap.
Old Dec 8, 2005 | 08:27 PM
swift2fly's Avatar
Car Info: My Car
I have a 2.5L hybrid swap with big cams and a rev limit of 7.5K using a vf34. here are my questions: will the final drive ratio suck? what top speed should i expect? and is the short gearing going to annoy me? can i expect good MPG? as far as power delivery..will it be better or worse?
i'm going the cheap route and plan to stick with the r160 rear diff. but ofcoarse swapping out the gear pinions and rings. so is the gearing of the r160 going to work with the tranny? thanks.
Old Dec 11, 2005 | 01:35 PM
pj21086's Avatar
Youre not going to get great mpg with short gearing, especially on the freeway. Your top speed will probably be significantly lower.
Old Dec 11, 2005 | 02:56 PM
slvrsubywgn's Avatar
Gas mileage only has to do with your right foot when you are messing with gearing. My gear ratios are lower since I changed out to RA gears and when I am going 63mph on the freeway I'm taching 3000rpm. So I drive alittle slower than everybody else and I get the same fuel mileage, if not better than before I changed it out.
I'd like to know more about the 6 speed spec C.
PacificLegacy
Aug 26, 2014 09:54 PM
UTWRX
Jun 23, 2005 09:03 PM
Haole-Pino
Dec 1, 2004 03:49 AM
t-wrexxx
Mar 14, 2004 07:39 AM
