Redline High-Pro gear Oil?
Old Jan 11, 2004 | 07:15 PM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
Question Redline High-Pro gear Oil?
Well I have around 14,000 "fun" miles on my STi and would like to change my Trany fluid. So I went to my local Redline store and picked up some 75W90 Redline High-Pro gear Oil.
The bottle says that's it's GL5 rated and it's the weight that the owners manual recommends but........
On the back of the bottle it says......"This product is not designed for use in most manual transmissions, since the extreme slipperiness may cause gear clash."
Now I know the STi 6-speed isn't most "manual transmissions" so you think I'm good to change the fluid out w/ the Redline fluid?
Old Jan 11, 2004 | 07:32 PM
funkdrmr's Avatar
Car Info: 2002 WRX Sedan - Silver
I don't own an STi, but when I changed mine, the shop recommended Amsoil 75w90 over RedLine, & they sold both. You may want to check out Amsoil if the RedLine isn't going to work with your tranny. I've been a happy customer with it too, if that counts for anything!
Old Jan 12, 2004 | 12:30 AM
Amsoil is more profitable for its dealers than Redline, so almost all of them will recommend it. If you want to run Redline, get either Superlight Shockproof or 75w90NS. Both are better for the synchros than standard 75w90.
Old Jan 16, 2004 | 04:00 PM
Mach5WRX's Avatar
Angry Dan
Bump!
Old Jan 18, 2004 | 02:42 PM
Mach5WRX's Avatar
Angry Dan
Damn maybe I can take it back.
Old Jan 22, 2004 | 06:39 PM
dr3d1zzl3's Avatar
Car Info: 08 sti
Check out hte NEO synth Racing gear oil. Supposed to be bad ***, havent had the chance to put it in my tranny yet tho.
Old May 16, 2004 | 01:29 PM
Mach5WRX's Avatar
Angry Dan
bump
Old May 17, 2004 | 09:57 AM
wolfen42's Avatar
Post
Originally Posted by DoomE.Q.
So THATS why my 5th gear takes 8 whole seconds to engage without grinding
Damnit...
Well at least it's not the worn out synchro I had thought it was...
-DE
Redline MT-90 is much better for your synchros.....
grambo
Misc Items For Sale
Aug 6, 2007 07:07 AM
topdog
Feb 8, 2007 12:46 PM
BattleD01
Oct 15, 2006 03:12 AM
blubaru
Jul 5, 2005 03:34 PM
eimmas
Apr 20, 2003 09:28 PM
