Problems with ACT Flywheel ?
Old Feb 2, 2005 | 08:23 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Question Problems with ACT Flywheel ?
Hey guys and gals-
I am ready to do my transmission install but before I do I want to make sure I have all my odds and ends matched up. I want a daily driver that is completely dependable. But I also want most performance that does not contradict my first statement. Here will be my setup
ACT Heavy Duty Street Clutch
ACT Pressure Plate
ACT Through out bearing
STi Braided clutch hose
STi Transmission mounts
I was wondering if anyone has had any problems with the ACT Streetlite flywheel, a guy that is a trusted person in the WRX scene told me that flywheels in general are totally poo poo. I want to know since the ACT flywheel sits at a heavier than average for aftermarket 13.9 lbs if that would mess anything up.
Austin
Old Feb 6, 2005 | 10:03 PM
WRX Rush's Avatar
Bump
Rush
Old Feb 10, 2005 | 04:43 PM
cleofis's Avatar
Car Info: 2001 2.5rs
it should be good... i don't see any reason why it wouldn't. i have a 16lb flywheel in my 2.5RS right now, but I'm upgrading my clutch/flywheel to basically the same setup as yours when i get my WRX motor swapped in.
I think the ideal weight for a flywheel is right around 13lbs, so I think you should be fine. You might want to e-mail Noah at LIC, they use ACT with all of their conversions.. Adam even uses them on his car which has seen many trackdays and 1/4s... hope this helps
Old Feb 10, 2005 | 05:22 PM
WRX Rush's Avatar
That does help me a lot, thanks I will give Noah a call today.
Rush
snowflow
Aug 20, 2012 01:01 PM
xicema17x
Mar 16, 2009 01:45 AM
FIA-WRX
Engine and Drivetrain
Apr 25, 2008 12:18 PM
Speed Element
Dec 6, 2007 05:24 PM
grex767
May 27, 2006 10:37 AM
