Act Sti Clutch With Act Or Crucial Flywheel 1099.00 Installed
Old Mar 26, 2008 | 12:22 PM
FIA-WRX's Avatar
Car Info: 05 sti
ACT Street Disc & Heavy Duty Pressure Plate Clutch Kit Subaru Impreza WRX / STi
WRX: Torque Capacity: 411 ft/lbs
STi: Torque Capacity: 475 ft/lbs.
Increase Clamping Force: 32%
Advanced Clutch Technology Heavy Duty Pressure Plates provide increased torque capacity, durability, and extended clutch life. What makes ACT Pressure Plates the highest standard in the industry? First, ACT manufacturing always begins with new units. ACT Pressure Plates are not rebuilt from worn out parts. Second, pressure is increased the right way. Altering the geometry alone is not enough. Instead, ACT engineers a stronger diaphragm. ACT diaphragms are heat-treated using an exclusive 3-stage process and the release bearing contact area is hardened to reduce wear. Third, ACT designs the pressure and release travel of the unit to be in the optimum working range. Finally, ACT assures consistency and precision by using proven assembly procedures. Every unit ACT produces is accurately balanced and tested. No guesswork, no hype, only proven engineering and calculated results for every ACT Heavy Duty.
Increased Torque Capacity
Extended Clutch Life
Stronger Heat-Treated Diaphragm
Hardened Release Bearing Contact Area
Accurately Balanced & Tested
1099.00 INSTALLED INCLUDES YOUR CHOICE OF ACT OR CRUCIAL RACING FLWYHEEL
Old Apr 3, 2008 | 01:50 PM
FIA-WRX's Avatar
Car Info: 05 sti
All PM's replied, 2 more in stock.
Old Apr 7, 2008 | 09:24 AM
FIA-WRX's Avatar
Car Info: 05 sti
bump
Old Apr 25, 2008 | 12:18 PM
Jeff@M4's Avatar
Former Sponsor
Car Info: Sti, Evo 2003+
PM's replied! only 1 clutch left at this price
snowflow
Aug 20, 2012 01:01 PM
FIA-WRX
Engine and Drivetrain
Apr 7, 2008 09:26 AM
gruppe-s
Dec 18, 2006 01:49 PM
gruppe-s
Dec 12, 2006 06:16 PM
gruppe-s
Nov 16, 2006 12:22 PM
