NEED HELP!!! transmission sound
Old Mar 11, 2013 | 11:47 PM
Xlagman92's Avatar
Car Info: 2002 subaru wrx
ok fellow Subie owners, my 2002 wrx bug eye, has this whine in first gear thats similar to reverse. BUT, i only hear the whine in first gear if my foot is DOWN on the clutch. the noise completely disappears wen i let off the clutch. any help? the whine sounds jue like reverse.
is this normal?
p.s. im PRAYING its not the throwout bearing because im a broke college student. haha. and i know its an expensive job....
any help is appreciated!
Old Mar 15, 2013 | 05:08 PM
subiekid916's Avatar
Car Info: 2009 subaru impreza 2.5i
Most likely your throw out bearing I have the same noise and hays what my mechanic said it was.... he also said it isnt a big deal until u hear it all the time even after the car warms up
Old Mar 17, 2013 | 07:02 PM
Xlagman92's Avatar
so you're saying i dont need to replace it or i should? i jus dont want my car breaking down on me out of no where you know?
Old Mar 23, 2013 | 02:36 PM
U only hear it when your foots down on the clutch pedal? And does it do it even after running the car for a while?
Old Mar 23, 2013 | 02:38 PM
Replace it if it bugs you and when they replace it if its something else they will tell u... my clutch went out had it replaced and I no longer have the sound I think you're referring to
Old Mar 24, 2013 | 02:15 PM
Xlagman92's Avatar
I haven't replaced it because my car runs good with no issues. the transmission feels great too. my clutch is good too. no slips, still grabs easy. jus don't want to blow hella money on something that isn't necessary.ive heard tons of different things...
-bug eye transmissions are loud
-the noise im hearing is normal
-the noise is from my throwout bearing
im jus wondering even if the noise IS my throwout bearing, does that mean I need to replace right away? or do I have like a year or so till it goes out on me? becuz I don't mind the noise, its jus the scare of having my car break down
Old Mar 25, 2013 | 10:09 AM
Basically since its a bearing it has grease in it and once the grease wears out that bearing is gonna go to hell... if u can find someone to replace it for pretty cheap I would the bearing itself is only like $15... call your regular mechanic if u have one and see what they say
Old Mar 25, 2013 | 10:11 AM
And what ever you do dont take your car to pep boys they suck ***... found that out the hard way
Old Mar 27, 2013 | 12:00 PM
Xlagman92's Avatar
Hahaha sure thing!! Hopefully they dont ask for a **** ton of money cuz i know pulling the transmission usually costs alot
Old Mar 27, 2013 | 12:02 PM
LOL_VTEC's Avatar
Car Info: 2018 Tacoma TRD PRO
2002 WRX have the worst 5-speeds.
Old Mar 27, 2013 | 12:12 PM
02RS25's Avatar
sounds like a throwout bearing. if you were hearing the noise when you were NOT touching or pressing on the clutch pedal, i would say its your throwout bearing retainers or pivot joint. would also be a pilot bearing possible. I replaced my clutch and neglected to clean and re lube pivot point and retainers. now it makes noise when at idle and off the pedal. if you were going to replace a bad throwout bearing yourself, that would be the ultimate budget saver. but if you dont feel comfortable with it, take it to a shop. GL!
Old Mar 27, 2013 | 09:44 PM
Xlagman92's Avatar
thanks! yea I dnt trust myself haha. ima jus have them replace the clutch wit the exedy oem replacement. and make sure they relube everything real well, including the things uve stated. my clutch had about 90k miles on it. I jus hate how the bearings can go out before the clutch itself.
Old Mar 28, 2013 | 07:27 AM
02RS25's Avatar
do you have any engine maintenance to perfrom that require pulling the engine? if so, pull the engine instead dropping the tranny. some drop tranny, some pull engine. it really depends what you are trying to accomplish
Old Mar 28, 2013 | 08:15 PM
Xlagman92's Avatar
nope! engine is healthy!
MindzeyeWRX02
Jan 6, 2010 01:35 AM
plac
Aug 27, 2008 01:34 PM
DesolationSuby
Apr 22, 2007 04:25 PM
mike
Nov 23, 2005 06:58 AM
