Help.. sti reverse lockout stuck at engage
Old Oct 15, 2005 | 03:08 AM
iwantasubaru's Avatar
Car Info: hello
Its not my car but a car i was looking at to buy, and the reverse lockout is stuck in the engage mode. how much does it take to fix this? and has this happened to anyone else.
Old Jan 19, 2006 | 11:06 PM
amye66's Avatar
Angry Same kind of issue PLEASE HELP
I have a hard time getting into 5th, and I don't need to pull up lockout to get into reverse ... what's going on? Please help.
Old Jan 20, 2006 | 02:27 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Reverse lock is a cable. So somewhere, the cable went boo-boo. I bet it is under the car. You can jack the car up and there is a goldish color assy that is connected to the cable. Right where the shifter linkages connect to the shiffter forks. Check it and make sure it is still attached there. Or, it could be on the shifter itself. Take the boot off and you will see how it engages and disengages so just check to trouble there.
Old Jan 30, 2006 | 04:38 PM
qingshan's Avatar
Car Info: '06 CGM Fo/12 SWP Sti
The cable must have a kink as the default is lockout
May involve a cable replacement (may be easier)
bflan2001
Oct 14, 2014 08:28 PM
Gcturismo
Jan 10, 2013 11:21 AM
idriveanSTi
Sep 13, 2009 11:43 AM
YuudaiSTI
Nov 18, 2008 03:48 PM
beth
Nov 24, 2003 06:42 AM
