HELP!!!...Just installed lowering springs and have HALF AXLE problems!
Old Aug 10, 2003 | 05:18 PM
McDade's Avatar
Car Info: 2000 RS Coupe/1990 Mazda Protege, zoom zoom..
having the axle come out of the hub is not a big deal as long as you put it back in ok.
Why did you take the axle nut off? That was unessecary, as you can pull the strut without taking that off.
Thats besides the point though. Make sure the nut is tight, that sucker has to be close to 200 ft lbs IIRC.
Jay
Racecomp Engineering
May 22, 2008 08:54 AM
grex767
May 27, 2006 10:37 AM
my02_impreza
Feb 16, 2005 03:13 PM
Zoeb2s
Feb 27, 2003 08:11 PM
