Gear oil leak!
Old Jul 10, 2004 | 03:10 PM
-j-'s Avatar
-j-
Car Info: 2006 Audi A3/2007 Civic Si
Gear oil leak!
Hey everyone,
Looks like I may have a gear oil leak. Can't seem to find it around the bottom area. Checked the fluid level and it did show as mid level on the stick.
The car has never been launched so it seems weird that even without abuse, this thing maybe going.
It's an 03 with about 22K miles. Kartboy was installed about 2 months ago. Last checked before that without any signs of fluid loss. Here's a photo on where the fluid is ending up....
Any ideas where to look for possible leak?
Old Jul 11, 2004 | 02:05 PM
RoadSpike's Avatar
My best guess would be the plug of the drain... though however unlikely it could be
here's a link to scoobymods with the gear oil change (membership to see pics)
http://www.scoobymods.com/forums/sho...1434#post11434
It will show you the location of the plug.
The only other thing i could think of is the main bushings/seals that connect the axel and to the crank. If the the crank one leaked it should have caused slippaged and burning smells from the clutch. The rear should be obvious though when they go they go usually pretty good.
Good luck on finding the real leak
Old Jul 11, 2004 | 09:27 PM
-j-'s Avatar
-j-
Thanks Roadspike. I did change the gear oil after the discovery and drove it to the Mt Hamilton meet. I checked the area again after and it showed a little more fluid so I think I will have to monitor this closely. I will be getting this thing checked out by MPJ hopefully this Saturday.
Thanks again!
Old Jul 12, 2004 | 01:41 AM
RoadSpike's Avatar
Thanks again!
keep me posted
i want the answer
Old Jul 24, 2004 | 01:54 AM
-j-'s Avatar
-j-
Roadspike,
I did find a leak on teh tranny. Right on the area where it meets, there are some bubbling going on when the tranny is real hot. I don't know if they will cover this under warranty. I surely hope so. If not....
Old Jul 26, 2004 | 09:24 PM
RoadSpike's Avatar
Roadspike,
IT actually BUBBLES!!?!?!
holy crap batman what the hell is going on in your car. It almost sounds like your cooking the Center diff.
Did you recently change like two tires?
Old Jul 26, 2004 | 10:39 PM
-j-'s Avatar
-j-
I believe the bubbles are just gear oil seeping out of a tiny, tiny opening. It's not quite the center diff area and I don't really drive like a maniac. I will try to see if I can tighten up the nuts in that area. I sure hope that works or I will have to get a GT
Old Jul 26, 2004 | 10:42 PM
-j-'s Avatar
-j-
No tire changes by the way and all seem to be even wear wise. I might try some stop leak to stop it.
Old Jul 27, 2004 | 12:34 AM
RoadSpike's Avatar
I suppose a vicious seal could be the issue but who really can tell without taking the tranny almost completely out
Oh an i thought you meant it was boiling.
salvator_rizzo
Jul 10, 2009 04:10 PM
yzercyber
Mar 2, 2008 06:02 PM
ScoobyRoo20
Sep 9, 2003 04:43 PM
bigdaddy
Jul 10, 2003 12:09 PM
Zoeb2s
Dec 30, 2002 10:43 AM
