4th gear problem
Old Mar 13, 2008 | 09:17 AM
DMC07WRX's Avatar
Car Info: 07 Subaru Impreza WRX
Question 4th gear problem
When I'm getting on the highway, at about 3 1/2- 4k. Shifting into 4th is really rough. And before letting the clutch out, it seems to make a short gring sound. The car is going in the shop for it's 6k service very soon. I just wanted some ideas before it goes. Sorry I just realized I should have put this in the tech forum!!!!!!!!!!
Old Mar 13, 2008 | 10:29 PM
EJ20PWR's Avatar
Car Info: 02 Bugeye STI, 07 Forester XT 18GXT-R
It has to do with the synchros. Mine does it too. Other than that i dont know. transmitions are not my thing.
Old Mar 14, 2008 | 02:15 AM
Scoobtastic's Avatar
Car Info: Turbo 2000(UK) model CG8....300bhp,more to come!!:
lathe shaft bearing is on its way out or its the clutch release bearing,also the the selector gator,something could well be jamming it,a mate of mine had the same problem with his,turned out to be a worn selector...easy cheap fix...
Old Mar 21, 2008 | 10:51 AM
RaginBull's Avatar
Car Info: E46 M. E36 M. E30. SW20. 92 VWCab.08 Civic HYBRID
just had my 4th and 3rd gear synchros replaced on my 05 STi. The car only had 17k miles on it so it was covered under warranty. Capitol Subaru did an excellent job by the way. I was told that the 04 -05 are manufactured with weak Synchros that are urethane coated as opposed to 06 and up which are carbon coated. Apparently, subaru recognized this as a problem thus changing them in later models.
This is a common issue. Just go to google and type in 4th gear grind WRX. Good luck!
DMC07WRX
Mar 14, 2008 07:23 PM
bushido
Oct 1, 2004 11:58 AM
02silversuby
Oct 14, 2003 11:15 AM
sleeperxt
Jul 23, 2003 02:11 AM
quick02rex
May 26, 2003 12:21 PM
