4th gear problem
Old Mar 13, 2008 | 09:26 AM
DMC07WRX's Avatar
Car Info: 07 Subaru Impreza WRX
Question 4th gear problem
When I'm getting on the highway, at about 3 1/2- 4k. Shifting into 4th is really rough. And before letting the clutch out, it seems to make a short grind sound. The car is going in the shop for it's 6k service very soon. I just wanted some ideas before it goes.
Old Mar 13, 2008 | 10:31 PM
EJ20PWR's Avatar
Car Info: 02 Bugeye STI, 07 Forester XT 18GXT-R
Its something to do with the synchros. mine does it to
Old Mar 14, 2008 | 09:00 AM
DMC07WRX's Avatar
Smile Thanks
Thanks for the ideas. like I said it's going in for service. That should be a warrenty job?
Old Mar 14, 2008 | 10:17 AM
EJ20PWR's Avatar
Most the time the dealership will tell you that its due to pilot error. Based off your screen name it looks like you have an 07. Depending on the dealership you should be able to have them fix it should you make enough of a fuss. Again depends on the dealer.
Old Mar 14, 2008 | 07:23 PM
DMC07WRX's Avatar
Ok!
I'm just going to let them keep it long enough to tell me it's not the driver. I'm a mechanic for Volvo. So I have some ideas of my own. The problem is I have 2 jobs. Very little time to even want to fix it myself!
DMC07WRX
Mar 21, 2008 10:51 AM
bushido
Oct 1, 2004 11:58 AM
02silversuby
Oct 14, 2003 11:15 AM
sleeperxt
Jul 23, 2003 02:11 AM
quick02rex
May 26, 2003 12:21 PM
