05 WRX - reverse and other gear problems
Old May 26, 2005 | 05:14 PM
gqchynaboy's Avatar
From: My lugnuts require more torque then your Honda makes
Car Info: 05 WRX
05 WRX - Reverse and other Gear Problems
It takes me lots of tries just to get it into reverse also if im at a dead stop and if i try just shifting it to other gears, it won't let me sometimes. I have only 750miles on my 05 WRX. Is this normal for a WRX or should I take it to the dealer to get it checked out?
Old May 27, 2005 | 09:13 AM
jonsWRX's Avatar
Car Info: 05 WRX
i had trouble with reverse for about 1500 miles. My reverse is worked in now but i dont know about your other gears. I would wait a little while longer, your gears might not be broken in yet. if it continues i would go ahead and have it checked out
Old May 27, 2005 | 10:36 AM
thebing's Avatar
Car Info: 2004 WRX
i've had my car for 20k miles and i have that exact problem you have. i think i've read other member responses about the 5th gear having no syncro or somthing. what usually helps is if you shift into first, get the car rolling just a tiny bit and shift into reverse. works every time. or another thing i try is just going to neutral clutch out, then in, and try again.
Old May 27, 2005 | 11:47 AM
Dave®'s Avatar
I've never owned a stick shift car that didn't need at least an occasional double-clutch to get into reverse.
Old May 28, 2005 | 08:55 PM
jlam86's Avatar
I have hte same problem as you in my 04. First gear and reverse tend to be a pain in subarus. I double clutch and it works out a little better. So clutch, put it in neutral, then clutch again in to the gear u want. hope that helps
Old May 29, 2005 | 12:54 AM
kumaWRX's Avatar
Car Info: 04 Toyota Tacoma
Sometimes I have trouble with reverse, but I always have trouble with first when rolling anything above like 10mph or so.
Old May 29, 2005 | 09:58 AM
tigsterz's Avatar
Car Info: 05' WRX STi
i always throw in a little rev, and it pops in R, np. i also have a 2005
Old May 29, 2005 | 10:44 AM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
thats what i did for reverse
Old May 29, 2005 | 12:20 PM
TurnWRX's Avatar
or go to 1st, 2nd, 3rd, 4th, clutch out, clutch in, then shift to reverse.
Old May 29, 2005 | 09:19 PM
Wingless Wonder's Avatar
Moved from WRX EJ20 turbo engine forum to Impreza transmission forum.
Old Jun 1, 2005 | 01:50 PM
elhaym's Avatar
Car Info: sonic yellow 03 WRX sedan
Sometimes it takes several tries to get in reverse on my 03 as well. I just put it in neutral, clutch out, clutch in, and try again. If that doesn't work after a few times, I put it in first, wait a bit, and try again. Pretty annoying.
Old Jun 1, 2005 | 06:15 PM
subabu05's Avatar
Car Info: 05 WRX Wagon
Suggestion
I had the, "WTF I can't get into reverse" in my05 wrx problem too. Sometimes I have a similar problem with shifting quickly through the gears. What I did, which I have found makes a significant difference in getting through the gears and especially into reverse, was installing kartboy shifter bushings. I installed the fronts practically since I bought the car. While they didn't help with getting into reverse they did help with a more solid shifter response. What did help I found, was installing a kartboy rear shifter bushing. I noticed right away that I didn't have to work that hard to get my car into reverse, it just fell into place like it was supposed to. Try it, at 35 bucks it's a worth while investment.
Ben
Old Jun 7, 2005 | 10:26 PM
Jimpreza's Avatar
Car Info: truck
Pump your clutch 3 times before putting it into reverse. This always works for me.
Old Jun 8, 2005 | 09:20 PM
jlam86's Avatar
i do that too! works sometimes and not at others
Old Jun 8, 2005 | 10:14 PM
T-Will's Avatar
Car Info: 2004 PSM WRX
I have an '04 WRX with around 26,000 miles and I've got the same issues going into R and 1st (while rolling). Just think of it this way, was the car really made to go into reverse? 99.999999999999999% of the time you're going forward anyways, so I'm not too annoyed.
MongrelXMutt
Subaru OEM Parts For Sale
Jul 30, 2013 09:57 PM
grex767
May 27, 2006 10:37 AM
verc
Jan 7, 2004 11:35 AM
rally04
Sep 14, 2003 07:05 PM
The Mirror
Jul 20, 2003 10:10 PM
