weird fan cycling and cel flashing someone help
Old Jun 13, 2004 | 01:24 PM
mrmodex's Avatar
i recently finished my swap and nw my fans cyle and my ecu turns on and off and my cel is blinking i cant figure it out someone help
Old Jun 18, 2004 | 08:53 AM
LICmotorsports's Avatar
Former Sponsor
From: 865 A Sweetser Ave.Novato, CA (new shop smell too)
Car Info: MY04 STi some call it a race car
Well it sounds like you may have the Test Mode connectors plugged in. They are the two green connectors under the dash near/above the OBD-II connector. When plugged in, the fans will cycle and the CEL will blink rapidly, but the ECU turning on/off sounds like it could be something different. Make sure you have your power wires correct, such as from the main relay, battery, and ignition. Hope this helps.
-Adam
adam@licmotorsports.com
mattsn0w
Mar 15, 2009 07:05 PM
Flauntinghippo
Aug 26, 2005 07:49 PM
808imprezaRS
Feb 19, 2005 07:36 PM
mrmodex
Jun 18, 2004 09:06 AM
superfly
Feb 18, 2004 09:04 PM
