Total conversion
Old Feb 21, 2007 | 05:44 AM
sinarty's Avatar
Car Info: 06' Subaru Impreza 1.6L Auto
Total conversion
MOVED:
You'll have to excuse me as I'm not sure where this goes or if the topic fits.
Alright, the victim: Subaru Impreza 2001, 1.6L Automatic.
Is it possible to convert it into a STI/WRX/?
I mean, swap for say EJ20T? or even 2.5L turbo engine?
swap the tranny and make it AWD? is that possible?
What are the necessary steps?
If someone could detail everything out it would be much appreciated.
Old Mar 6, 2007 | 04:54 AM
sinarty's Avatar
up
Anyone?
I got another question,
Is the chassis the same on all versions? WRX STi and the regular, 1.6L auto FWD?
Old Mar 6, 2007 | 03:19 PM
fenderstrat066's Avatar
Car Info: 2004 Wrx
Yes it is possible. It has been said that subarus are like lego's, they are very interchangeable. Any model from 92-07's drivetrain can be swapped with a little work. This has been discussed many times so you can just search it so i dont have to explain. I will say that you can change it to AWD, you can put a 2.5L turbo motor in, and you can make it a 6speed.
Old Mar 7, 2007 | 09:42 AM
sinarty's Avatar
Some people told me that STi has a different chassis... Meanning I can't swap in an STi motor...
Are you one hundred percent sure about this?
Cause' I'm about to go on with the project if what you are saying is true...
I just need to be 100% sure it will work... Hope you understand
I'd like to hear more opinions if its possible.
Thank you.
Old Mar 7, 2007 | 10:06 AM
VRT MBasile's Avatar
WRX and STi are the same chasis if you can put in a wrx motor, you can put in an STi motor
Old Mar 7, 2007 | 11:38 AM
sinarty's Avatar
Was it ever done before?
Old Mar 7, 2007 | 05:50 PM
1sicwrx's Avatar
To my knowledge the front subframe is different on the N/A Imprezas from the turbocharged ones. You would have to swap a subframe from a WRX or an STi.
Old Mar 8, 2007 | 09:07 AM
sinarty's Avatar
whats a subframe?
Old Mar 9, 2007 | 06:44 PM
1sicwrx's Avatar
Originally Posted by sinarty
whats a subframe?
I hope your not doing the swap yourself if you don't know what one is. Anyway, In order to have the turbocharged motor cradled in a secure manner as well as much different exhaust routing than the N/A power plant. Therefore, it will require you to swap front subframes in order for everything to fit. Serach this forum for "front subframe", you shouldn't have a problem.
Old Mar 13, 2007 | 03:22 PM
sinarty's Avatar
Nope, I'm not doing the swap myself since I don't have any experience whatsoever.
I just have money, my passion and love for cars.
Thanks for everything, I appreciate everything that has been said here.
Thank you.
Old Apr 12, 2007 | 05:39 AM
LiBrT Nut's Avatar
Car Info: 90 lib gx ej20tt
the only thing needed to be changed for n/a to turbo is that u will need to change the crossmember in rfont of the gearbox because the dump pipe fromthe back of the turbo hits the standard 1 while the other has an indentation in it that allows your exhaust to pass over the top also wiring loom ecu fuel pump will also need to be changed 2. in short putting the motor in the car is easy but making the engine manament run it is a pain but definatly possible. as fender strat said they are like lego i have a twin turbo b4 motor in a 90 model liberty/legacy wagon so there is 12 yrs differnce between the age of my car and the half cut i raided the motor from. so good luck with the project.
sinarty
Feb 21, 2007 10:12 AM
Happy_Days
Canada
Aug 23, 2003 12:47 PM
KnightRider
Jul 24, 2003 08:28 AM
OwlBoogie
May 24, 2003 12:58 AM
