swaping 03 bugeye to 04 motor and trans info needed
Old Sep 5, 2010 | 03:01 PM
hawk1's Avatar
Car Info: 2003 wrx wagon
will i need to swap computer
will i need to swap axels
I have doner 04
thanks for your help
Old Sep 5, 2010 | 03:07 PM
Alliedforces86's Avatar
Car Info: FR-S + WRB Bugeye.
As long as it's a WRX 5-speed from the 04 you should be fine. Everything should bolt right up no problem. Meaning you shouldn't have to swap axels, and wagon axels are shorter than sedan( since wagon wheel base is shorter) you'll want to keep your stock ones. Hopefully someone can confirm that for me, but I'm pretty sure there's a difference between the sedan and wagon axels.
As for the engine, you should swap everything you can so there is as little problems as possible.
bluebiker
Jun 22, 2006 10:41 AM
Aln
Mar 16, 2004 03:11 PM
bigal52
Feb 28, 2004 09:11 PM
xsilverguyx
May 7, 2003 05:46 PM
WickedPlayaX
Dec 31, 2002 09:53 AM
