STi motor swap
Old Feb 13, 2005 | 10:28 AM
kindil's Avatar
Question sti moder swap
I was just woundering can an sti motor and tranny be dropped into say a 98 impreza L or what is the latest model 2 door that an sti motor can be dropped into.
Old Feb 13, 2005 | 10:39 AM
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
Try this thread next time, you will get a better response.
https://www.i-club.com/forums/forumdisplay.php?f=107
Old Feb 15, 2005 | 01:10 AM
Wingless Wonder's Avatar
The drivetrain can be swapped into some earlier models and even into models other than the Impreza but it's not always simple. An article on swapping a WRX engine into an Outback published in Sport Compact Car Magazine about a year or so ago told that the tough part was the wiring harness conversion which took many, many hours to do correctly. This is necessary if you want to use the factory type ECU, which is more advanced than earlier ECUs. If you go with aftermarket engine management, you avoid the hassle of wiring the car but you'll have to learn how to tune it or find someone who can do so.
Old Feb 15, 2005 | 11:38 AM
ds baruuuuu's Avatar
Car Info: 5.4RS
wiring in an aftermarket ecu would be the same the hardest and most time consuming part is labeing and finding all the wires after that its just a matter of untaping the harness and soldering in the power and misc wires... not as bad as everyone makes it sound
PacificLegacy
Aug 26, 2014 09:54 PM
greenpoop
Jul 9, 2009 08:31 PM
FLIWRX
Engine and Drivetrain
Apr 30, 2007 01:27 PM
c279a
Oct 26, 2006 04:07 PM
