Question on Engine Swap
Old Jan 27, 2005 | 06:10 PM
As far as the physical swap part of the engine, it's very simple and straight forward. there is no fabrication needed, you can use a stock part for everything, as long as you have the right one. Wiring is the difficult part; you can (and should) use a complete wiring harness from the donor car for yours. This is how most shops do it. the best thing to do is talk to a shop that has swap experience and ask them.
Old Jan 27, 2005 | 08:49 PM
joubtt's Avatar
Car Info: 00 2.5RS
You'll need the complete(uncut) wiring harness, ecu, turbo, the stock exhaust(unless your upgrading), the fuel controller+pump, upgraded clutch and another car/truck to get around while you wait.
If you're in Socal, they're a few shops to choose from and tuners also.
MisterSheep
May 5, 2016 08:11 AM
PacificLegacy
Aug 26, 2014 09:54 PM
joltdudeuc
Oct 2, 2012 09:51 AM
gillz
Aug 21, 2011 10:21 PM
Two Wheel Fiend
May 2, 2003 08:41 PM
