Engine weights
Old Feb 16, 2005 | 07:51 AM
Kreb's Avatar
Engine weights
I'm considering the 2.5 4 cyl and 3.0 6 as possible kit car donor engines. I particularly like the low cg, and the room to work/add accessories. I used to autocross a friends WRX around and quite enjoyed it. Can anyone tell me how much these engines weigh? Will the 6 cylinder mate up to the 4 cyl gearbox? Any particulars of these two engines that I should know about? I've not mentioned the WRX engine because it's more expensive, and I want something with a broader powerband.
Thanks for any and all input
-Berk
If you're interested: Here's my current kit car:
http://www.smm.com/gallery/full-body-V3
Old Feb 16, 2005 | 07:57 AM
Nick Koan's Avatar
Car Info: Legacy GT
The 6 cyl motor can bolt up to the gearboxes designed for 4cyl. I don't know how many custom brackets and mounts you'll need to make, but hey, you're building a kit car
I assume it shouldn't be any worse then mounting any tranny in a kit car.
Old Feb 22, 2005 | 01:21 PM
i2()N!N's Avatar
Car Info: 98'RS
woah, how much does one of those kits cost.
cool
Old Feb 22, 2005 | 07:19 PM
Kreb's Avatar
So that weight is with alternator and manifolds? Not bad!
Thanks.
Any more?
Old Feb 22, 2005 | 08:17 PM
I don't know the exact weights, but I can give you rough order of lightest->heaviest. Starting with EJ25, then EJ22, then EJ18 (basing this on near-identical blocks, except the larger engines have more bored out of the cylinder walls, and similar SOHC head designs except for Phase I EJ25s) then EJ20s, then the 6 cylinder engines. The EZ30 was significantly heavier than the EJ25 despite having near identical outer dimensions.
Old Feb 23, 2005 | 12:36 PM
EricDaRed81's Avatar
Dirty Redhead
From: Commuting? I don't know what that means anymore.
Car Info: 05 WRX Wagon (Crystal Gray)
EJ22 long block, no accessories or intake manifold- 188 lbs.
I found this one I'll see if I can get the rest
Old Feb 23, 2005 | 12:43 PM
Kreb's Avatar
You're really peaking my interest. So the EJ 25 is lighter than the 22, which isn't bad at all. That's very encouraging. It really makes me wonder why I don't see more of these in kit car applications. A low CG, light weight and torquey motor seems just the ticket for a 1200 lb. car.
Old Feb 23, 2005 | 06:56 PM
I'm just guessing on the EJ25,22, and 18 non turbo motors. They are all going to be very similar in weight.
Meyers
Jul 4, 2004 06:28 AM
Silverbullet04
Apr 5, 2004 04:32 PM
Choku Dori
Jan 7, 2004 09:19 PM
lovinwrx
Dec 17, 2003 08:31 AM
inthedeck
Jul 11, 2003 08:18 PM
