Power problems - no boost
Old Feb 1, 2011 | 07:59 PM
AntiochCali's Avatar
Car Info: '03 WRX wagon, faster than walkin'
My car no longer boosts - when I get to positive pressure it bucks and jumps and doesn't go.
Any ideas of what to look at?
Old Feb 1, 2011 | 08:46 PM
johndabrit's Avatar
Da Brit.
Boost leak. First thing to check is the intercooler hoses followed by the inlet. Prob time for a pressure/leakdown. Your turbo could be shot. If you have an egt it may have snapped off and traveled up the pipe into your turbo. If it bucks you might have a fuel delivery problem. Your pump may be going out or fuel filter may be clogged.
Old Feb 1, 2011 | 08:50 PM
GD916's Avatar
Car Info: Wrb bugeye
I'm gonna say it before Paul at DB tuned does... Get it diagnosed by a certain shop that works on Subarus
Old Feb 1, 2011 | 11:26 PM
FXTbrah's Avatar
previously known as wrxBRAH
Car Info: 2004 FXT
Had any work done recently? CEL? To be on the safe side take it to a shop that works on wrxs.
Old Feb 2, 2011 | 01:15 AM
Lurk's Avatar
Check your intercooler hoses. I've had an IC hose pop off before and the symptoms sound exactly like what you're describing.
Old Feb 2, 2011 | 06:16 AM
Heedz's Avatar
Nobody likes the tuna here
crack in any couplers and such?
Old Feb 2, 2011 | 08:28 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
It really could be many things with the symptoms you're describing. Take it to a good shop for diagnosis.
-- Ed
Old Feb 2, 2011 | 12:26 PM
thanks all, I was thinking along the lines of fuel pressure....but it could be intercooler. I'll dig around a bit.
Old Feb 3, 2011 | 12:12 AM
salvator_rizzo's Avatar
everyone pretty much covered it. I had the same thing happen on my car, the turbo inlet hose got worn out and it developed a split/hole or whatever. It's made of rubber and constantly gets really hot, then cold etc. wears out quick
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
dyepball1
May 18, 2006 10:23 AM
westsidedfd
Feb 13, 2006 01:15 PM
yzercyber
Aug 12, 2005 03:42 PM
Top
