Need help diagnosing a problem...
Old Apr 18, 2005 | 03:15 PM
OneManArmy's Avatar
General Pimpin'
I had a similar problem today.
Car turned over and over but wouldn't start. I had to jump it yesterday. But it got started twice and drive from san jose to sf today....the battery should have recharged in that amount of time. I do have a stereo. 800 watts total.
But it's pissing me off. errrrrrr.
I hope mine is just a battery or something small.
Hopefully it's just your battery. I wish I had a tester to test my isht.
Good luck.
Old Apr 18, 2005 | 08:40 PM
AntiochCali's Avatar
Car Info: '03 WRX wagon, faster than walkin'
my battery is dying too -
Old Apr 18, 2005 | 09:49 PM
Group B's Avatar
Dahveed aka Robin Hood
Good luck.
If you're have that powerful of an aftermarket stereo system, it doesn't matter how long the drive is, you're overloading the available output of your alternator and you're going to drain your battery.
You might want to look into the JDM higher-output alternator or and aftermarket/rebuilt unit that offers higher amperage output, or you WILL eventually burn out your alternator and your battery.
Old Apr 19, 2005 | 06:38 AM
motoracr22's Avatar
Car Info: 96' Impreza GM4
Originally Posted by RussB
the voltage should be in the mid to low 14's
A battery in a good state of charge should be 12.6 volts just sitting there. Engine on, and charging should be around 14. Below 9.6v, and it's not going to crank most likely.
Old Apr 19, 2005 | 10:52 AM
Japsican's Avatar
Car Info: 2012 DGM STi Sedan
Quick Question...
I picked up an Optima 35 from AutoZone however after installing it I found that the cables are too short...Any Idea on how to remidy this situation? Thanks!
pantyraid
Sep 28, 2012 11:49 PM
YuudaiSTI
Jun 6, 2011 02:16 PM
deportedflip
Mar 27, 2011 04:28 PM
Pactin
Jul 7, 2009 09:47 PM
r90srider
Apr 12, 2005 07:02 AM
