Help!!! my engine is..
Old Oct 20, 2009 | 07:12 PM
  #31
leftcoast_650's Avatar
Car Info: EQ Tuned Wagon ;)
Originally Posted by EQ Tuning
Great to hear... so it was just the spark plugs?
yup! just the spark plugs and Ed i might be seeing you before the new year for another tune
Originally Posted by ipozestu
Old Oct 20, 2009 | 09:08 PM
  #32
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Originally Posted by leftcoast_650
so i compression tested today with the help of brian (07wrx4life) we hit a snag with the piece of crap auto zone tester anyway my friends dad fixed that problem and i got another tester since the motor hasnt been ran since yesterday i had these numbers
cyl #1 - 152psi
#2 - 150psi
#3 - 150psi
#4 - 149.5psi
so i swapped in new plugs and for a tester i switched the coil pack with the problem cylinder with another. started it up and let it run for 20 min while revving it up every now and then and it still has no CEL. while last night it would come on within the first minute of idle. so i think i took care of that problem.
i now need a gauge pod so i can hook up a boost gauge i need to see if there is a boost leak..
Those are cold numbers, correct?
did you have the gas pedal pressed to the floor whilst cranking?
Old Oct 20, 2009 | 09:09 PM
  #33
yes those are cold numbers (overnight) with the throttle wide open
dpulse2930
May 18, 2015 05:27 PM
dpulse2930
Apr 9, 2011 12:18 AM
SilverRex04
17
Jan 4, 2005 01:54 AM
seb
Jun 1, 2003 12:30 PM
rash
May 17, 2003 12:32 PM
Top
