confusing clunking noise. HELP!
Old Oct 2, 2011 | 07:52 PM
bkblitzed's Avatar
Car Info: Miata and dirtbikes
I have this really confusing clunking coming from my suspension somewhere. I have kw v3 coils on my 04 sti, and every time it either compresses or decompresses it makes a loud clunk. I thought it was my camber plates so i switched back to oem top hats, and it is still making the loud clunk. I thought it was my swaybar, but its on correctly and the endlinks seem fine. Idk what it is..
Old Oct 2, 2011 | 08:06 PM
OneManArmy's Avatar
General Pimpin'
How low are you set.
slugrx's Avatar
Car Info: 04 psm wrx sedan
front or rear
OneManArmy's Avatar
General Pimpin'
If your in Salinas tomorrow come by my office.
Old Oct 2, 2011 | 08:08 PM
bkblitzed's Avatar
well now im kinda low, but before i was about 4-5 inches from the ground, and that was with the lip, but the clunking has always been there. Idk its my rebound or something -.-
e: fronts only
Old Oct 3, 2011 | 09:28 AM
slugrx's Avatar
I had a noise like that...the rubber piece that sits between bottom spring and shock had somehow moved and so I was gettin a little spring/shock touching..not sure this is your case but look around and you may be able to see what is touching (look for rubbed off spots or damage)
Old Oct 3, 2011 | 12:06 PM
OneManArmy's Avatar
General Pimpin'
If I can't figure it out today id make an apt at auto innovations and have them look over your suspension. A lot easier to diagnose on a lift.
Old Oct 4, 2011 | 03:25 PM
cyyeo's Avatar
Just a suggestion, before you start looking into all the suspension stuff, I would suggest that you look at the torsion bars for the rear trunk lid. Mine would make the same noise, every time I go over a bump. I replaced both the torsion bars and the noise went away.
Old Oct 12, 2011 | 06:54 PM
JooseyJeff's Avatar
Car Info: 06 TRD Tacoma
I have this damn clunking noise, too. Mine's coming from the front passenger's side. I jacked it up, took the tire off, and couldn't see anything out of the ordinary...end links seem fine; no irregular rubbing spots.
It's weird, I can recreate the sound easily when I'm going very slowly and step on the brakes suddenly. I'm thinking it's the bushing between the spring and the shock tower that's been tweaked somehow...I guess I'll be disassembling the whole assembly to find out
Old Oct 12, 2011 | 07:07 PM
wilde's Avatar
Car Info: 05 white WRX
I have the same noise in the front passenger side but on stock suspension.
Old Oct 12, 2011 | 07:14 PM
bkblitzed's Avatar
it went away. I guess the stock top hats needed to be seated in or something
Old Oct 13, 2011 | 09:53 AM
JooseyJeff's Avatar
yeah mine's stock, too
Old Oct 13, 2011 | 10:00 AM
OneManArmy's Avatar
General Pimpin'
sweet.
You should here the clunking in my car. LOL. Stupid seized end link. One of these days I need to put a new set on there. haaaaa.
If it come back swing on by.
Gregsbluerex
Jul 25, 2004 11:11 AM
thejean
May 9, 2004 12:06 PM
DWNSHFT
Jan 21, 2004 10:48 AM
izhazissuez
Oct 7, 2003 10:06 AM
flyingace
Jan 11, 2003 02:10 PM
