Oil Cooler Gasket Leak
Car Info: 2006 Subaru WRX Wagon
134k miles
I have the typical leak by the oil cooler. Ive changed the gasket between the oil cooler and the oil cooler bracket...one week later. still leaking. I just did it again tonight and i believe theres still a leak.
I originally thought I did get a good seal on the gasket but doing it twice. I know i did the second time. Has anyone have experience with the other 2-3?? gaskets that sit higher up on the bracket between the block and the oil cooler?
picture for reference, this is before I changed it out the second time
Car Info: 2005 Subaru WRX
I have this same problem. I believe there are like 3-4 o ring gaskets in the cooler. I wanted to try the top one first (between block n cooler) and work my way down till its fixed. How hard was the top gasket u changed?
Car Info: 2005 Subaru Wrx STi
I there is only one oil cooler gasket dude. Its between the block and the cooler it's orange. There is also one on the oil filter. If you replace both and it's still leaking your cooler itself could be leaking
salvator_rizzo
07-10-2009 04:10 PM
yzercyber
03-02-2008 06:02 PM
Zoeb2s
12-30-2002 10:43 AM
