For the guys with cams...
Car Info: 04 wagon
What are you running & whats your setup? Ive been thinking about maybe upgrading the stockers in my build. Nothing to big, I was looking into the Kelford 264's & GSC s1 cams, but they seem to have had a quality control issue lately. Just curious what everyone is running and if you have had problems or regret your choice. Thanks guys
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
https://www.i-club.com/forums/garage...6-Brfatal.html
I went with GSC S2s, which I'm finding out were too aggressive for street use. I should have stuck with S1s.
Car Info: 04 wagon
i-Club - Garage Portal
I too have heard of all of the reputable cam brands being unreliable and breaking. The only one I haven't heard of having issues, is Brian Crower Cams even though their cams run a much lower profile than stated. I.E. 272s are 264. However, they seem to be the most reliable 2nd to stock and gives a bit more power.
Brian Cower is the the one I hear the most about with issues (from poor fitment to cracking). I know of a shop who won't sell or install any of their products.
GSC seems to be the most consistently reliable, so that's what I went with. I haven't heard of their more recent issues.
Cosworth/Kelford had issues when they switched their manufacturing to China, but I don't know if those problems remain.
I will also bring up valvetrains. Whatever you do, stay away from BC and Supertech.
Car Info: 04 wagon
Alot of pages, but some good info on the current problem some builders are having.
NASIOC - View Single Post - Anyone else have this issue with Kelford Cams?
GSC's problems seem to be from within the last year or so. I hadn't heard it. Good to know. I honestly don't know who I would recommend then. Kelford (who makes Cosworth's) has had their issues for a few years now.
They are older issues but ones that that persisted for a very long time, which tells me something about the company's QC abilities. And yes, BCs are known to give you the **** poor idle you want and none of the power that goes with it.
It's pretty telling that he told you to use stock.
Car Info: 04 wagon
Yeh, I might just end up sticking with stock since I have a good thing going with it. Just was thinking about reaching for some more power. Im swapping in a EL header, a higher psi wastegate (since my current wont go about 22psi) and a better intercooler which should see some decent gains I think. Just was curious on cams. Im going to ping some engine builders and see what they are using lately.
The Tomei specs isnt really worth the trouble of pulling the engine for me right now.
I came in to post this, but houdni beat me to it. Tomei is famous for their cams. One of the few companies who still makes their **** domestically. I plan on using a Tomei shortblock whenever my 06 Evo motor goes.
Car Info: LUMPY CGM 05 WRX
I am running cosworth 272's on my hybrid. Honestly on my td-04 all they did was make it sound cool.
Now that I am on the dom 3 they have made a significant difference on the top end ability but I am exceeding my rpm range on my stock heads.
I have 40k miles on them with no issues.
My next motor will have non avcs 2.5 litre heads with lots of work over sized valves and heavier valve springs. It is the cams that are going to get this little baby to 8.5k redline.
With my v7 6 speed I am hoping to mitigate the shift into 5th on the strip for lower E.T.'s
If you are not planning on doing that kind of work my understanding is the stock cams work fine they are great for torque and there are many high hp builds running stock cams.
