2008 sti HELP!!!!!!!!!!!!
make sure your paying attention to which flash your performing. i think one is a reflash and the other is well i cant remember at the moment. but i know the reflash stays programed after the car has been shut off. the other i dont think will. i beleive it will revert back to the original tune once the ecu loses power.
what i think happened was you have done the reflash with the e85 and then did the temporary ecu flash when you went to 93. if so it probably ran fine for a bit and then once you shut your car off the ecu reverted back to the e85 map and started squirting in more fuel than needed. but this would inturn run your afr's really rich and probably throw codes so maybe not. but its a possibility.
Car Info: his wife crazy
Car Info: 08 WRB/Gold STI. EQ Tuned, E85, 340whp 390wtq
If you confirm the reflash is done correctly, & your map is correct for your fuel type, then if it still has the jerk or stumble around 2.8k rpm then you need an extra 3ft of fuel line installed after the damper. Fixed mine, many threads on here & iwsti on this topic if you have a search around
twinturbozs
10-22-2012 01:35 PM
ArchangelX
06-18-2008 04:42 PM
