Best engine setup for RESPONSE
Old 05-25-2014, 11:56 PM
Xlagman92's Avatar
Car Info: 2002 subaru wrx
hey guys, so i have a 03 wrx and want to mod my engine to be responsive for touge and autox. any reccomendations? or is it all in the tune? any info and input is much appreciated!!
Xlagman92 is offline
Old 05-26-2014, 09:59 AM
awdorgtfo's Avatar
Car Info: 07 UGM WRX Wagon
Equal length headers and a small turbo
awdorgtfo is offline
Old 05-26-2014, 12:50 PM
Xlagman92's Avatar
Thanks! So its proly a good idea to stay stock on turbo
Old 05-26-2014, 12:54 PM
ddavis's Avatar
Car Info: 04 wagon
Best engine for response? You need more displacement.
ddavis is offline
Old 05-26-2014, 01:01 PM
awdorgtfo's Avatar
LS swap dat *****
Old 05-27-2014, 10:03 AM
Nobody likes the tuna here
Heedz's Avatar
Location: Somewhere San Mateo County, Inside A 911 Ambulance
Go NA.... or.... stock turbo e85.
Heedz is offline
Old 05-28-2014, 06:38 PM
Superusdm's Avatar
Car Info: 2003 WRX
Yea stay stock on the turbo. Ported stock manifold and e85 would Likely be a good combo, with a MBC.
Superusdm is offline
Old 05-28-2014, 09:25 PM
jdblock's Avatar
Car Info: 2004 STI
Raise the compression ratio. Higher compression increases response.
jdblock is offline
Old 06-01-2014, 05:40 PM
Xlagman92's Avatar
been hearin alot of good things about a ported manifold! thanks guys!
Old 06-01-2014, 07:43 PM
RAWeiss's Avatar
Car Info: WRB Wagon
you've heard right, I've got the grimmspeed pnp'd manifold w/ the high flow cross pipe, significant difference in low end response/spool which definitely is lacking on our 2.0's.. even more so than when I had my borla UEL headers IMO
RAWeiss is offline
Old 06-08-2014, 10:08 AM
Heedz's Avatar
Full headers will allow the turbo to spin slower but longer.
Heedz is offline
Old 12-27-2014, 03:08 PM
RAWeiss's Avatar
Car Info: WRB Wagon
True a full header will allow for more mid/top end regardless of UEL/EL, although if i was going to do a header again I'd just go full EL since it really gives you more power throughout the rpm's + spool
PnP manifold/x pipe is more of a solution for the 2.0ers I think since you gain much more low end/spool, i.e on a vf'd 2.0(like myself) and still want the rumble
Otherwise EL is better in every way essentially, just gotta come to terms with losing your boxer rumble
RAWeiss is offline
revhigh96
10-02-2004 08:59 PM
DreddRS25
03-25-2004 10:24 PM
whiterabbit
12-03-2003 09:33 PM
blackwagonrx
03-18-2003 06:08 PM
Impreza_WRX_STi
01-21-2003 05:55 AM
Quick Reply: Best engine setup for RESPONSE
