Wheel/Tire/Car Fitment Database
What Fits Listing (Post what you have)
I think it would be a great addition to have a sticky topic with a listing of what combinations fit and which ones don't since half the post are asking if xxx with yyy fits. It wouldn't be a sure thing, but it would definitely be a place to start. Each post would need to include:
Car model and body style (year and sedan/coupe/wagon)
Wheel model, size, and offset.
Tire model and size.
What suspension is used and what kind of drop; including adjustments like camber that may influence the fit.
If rolling was necessary.
I'm not sure if it could be broken down into a couple topics; 1 for those that do fit and 1 for those that don't. Just an idea.
Here's the template - copy/paste/post.
Year: xxxx
Model: xxxxxxxxxx
Body Style: xxxx
Wheels: xxxx
Diameter: xx
Width: xxx
Offset: xxx
Tires: xxxxxxxxxxxx
Big Brakes?: xxxx
Suspension: xxxxx
Drop Front: xxxx
Drop Rear: xxxx
Camber Front: xxxxx
Camber Rear: xxxxx
Rolled Fender Front: xx
Rub?(where): xx
Year: xxxx
Model: xxxxxxxxxx
Body Style: xxxx
Wheels: xxxx
Diameter: xx
Width: xxx
Offset: xxx
Tires: xxxxxxxxxxxx
Big Brakes?: xxxx
Suspension: xxxxx
Drop Front: xxxx
Drop Rear: xxxx
Camber Front: xxxxx
Camber Rear: xxxxx
Rub?(where): xx
Year: 1998
Model: Impreza RS
Body Style: Coupe
Wheels: Stock
Diameter: 16
Width: 7.0
Offset: +53
Tires: Dunlop SP5000
Suspension: SPT Springs on SPT (AGX) struts
Drop Front: 0.75"
Drop Rear: 0.75"
Camber Front: -2°
Camber Rear: Stock + drop induced
Rolled Fender Front: No
Rub: No
If it rubs please state where it rubs.
Model: Impreza RS
Body Style: Coupe
Wheels: Stock
Diameter: 16
Width: 7.0
Offset: +53
Drop Front: 0.75"
Drop Rear: 0.75"
Camber Front: -2°
Rub: No
Year: 2002
Model: Impreza WRX
Body Style: Sport Wagon
Wheels: SSR Competition
Diameter: 17
Width: 7.5
Offset: +50
Tires: Michelin Pilot Sport PS/2
Suspension: Stock
Drop Front: None
Drop Rear: None
Camber Front: Stock
Camber Rear: Stock
Rub: No
Model: Impreza WRX
Diameter: 17
Width: 7.5
Offset: +50
Suspension: Stock
Drop Front: None
Drop Rear: None
Camber Front: Stock
Camber Rear: Stock
Rub: No
Year: 2003
Model: Impreza WRX
Body Style: sedan
Wheels: formula mesh (volkner, not volk)
Diameter: 18
Width: 8.0
Offset: +48
Tires: Falken
Suspension: DMS 40 coilovers WITH cusco camber plates
Drop Front: 2.0+
Drop Rear: 2.0+
Camber Front: not measured
Camber Rear: not measured
Rub: No
Model: Impreza WRX
Body Style: sedan
Diameter: 18
Width: 8.0
Offset: +48
Tires: Falken
Drop Front: 2.0+
Drop Rear: 2.0+
Rub: No
Car Info: 02' Black Wgn
Year: 2002
Model: wrx
Body Style: wagon
Wheels: 5-zigen fn01rc
Diameter: 18
Width: 8
Offset: ?
Tires: ventus plus
Big Brakes?: no
Suspension: B+G spring + stock shocks
Drop Front: 1.4
Drop Rear: 1
Camber Front: stock
Camber Rear: a little negative
Rolled Fender Front: no
Rolled Fender Front:remove rubber liner
Rub?(where): All I had to do was remove the little rubber fender trim peace and no rubbing at all
Model: wrx
Body Style: wagon
Diameter: 18
Width: 8
Offset: ?
Tires: ventus plus
Big Brakes?: no
Drop Front: 1.4
Drop Rear: 1
Camber Front: stock
