Ticking noise after mounting and balancing tires.
Old Nov 18, 2005 | 10:41 PM
black_sti's Avatar
Car Info: 2005 Black STI w/ Gold Rims
i just had my tires mounted and balance and as i was driving i realized that my car kept ticking wen im moving. the ticking is only noticeable from 0-45 miles and after that u cant hear it nemore. wat can this be? i doubt it is my axle or cv boots becuz its a 3 month old car. it is a 2005 sti does neone know wat this is? thank you.
also as they were removing the factory wheel weight that balance the tires that left scratch marks on all 4 rims. have this happened to neone else as well?
Thanks.
Old Nov 19, 2005 | 05:08 AM
9Vapors's Avatar
Car Info: 02 WRX
New tires can get rocks stuck in the tread very easily, check them for a stuck rock, it might be the culprit.
Old Nov 19, 2005 | 10:31 AM
boomer's Avatar
Car Info: 99 2.5rs
I just had advan ad07 put on my 05 sti and what you might be hearing is rocks or the stickers that they put on the tiers.
Old Nov 19, 2005 | 10:37 AM
black_sti's Avatar
^ yea the stickers are not fully ripped out. there are still some sticker stuck on it. can this be a problem?
Old Nov 19, 2005 | 11:31 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
3 things can do that.
1. Something got stuck in the tread.
2. Stickers still on the thread.
3. Weight stickers are hitting something. Caliper or brake line.
I bet it is #3.
Old Nov 19, 2005 | 11:51 AM
Group B's Avatar
Dahveed aka Robin Hood
I bet it is #3.
I bet it is too, because there is very little clearance for sticky weights (they have to use the ultra-thin ones) between the calipers and the wheel surface.
Old Nov 19, 2005 | 12:35 PM
black_sti's Avatar
yes u guys are correct. it is #3. can this be fixed or will i have to live with it? it is eating away my brembo paint =(. also do the stock weights scratch ur rims wen they r removed? mine all r scratched from the stock weights.
Old Nov 29, 2005 | 02:43 PM
B@LL@R's Avatar
Car Info: 2004 WRB WRX
Talking Check All You Lug Nuts!!!
What you are describing is exactly what I was having. I just had the same thing happen to me but i had a much scarier ending. I ended up loosing 4 lug nuts B4 I found the problem, 2 were off the drivers side front tire, and 2 more were about to fall off other wheels, I thank god that a tire didn't come off on me.
oops, I should read the entire thred first... My bad, I retract my statement
Old Nov 29, 2005 | 06:47 PM
HomerJay's Avatar
Car Info: MY00RS25
Take it back to where you had the tires mounted and balanced and have them fix it asap. They are the morons who didn't do it right, make them pay for your calipers to be repainted. The stock weights leave a tiny mark on the rim. Not very noticeable.
i<3dirt
Oct 20, 2014 10:26 AM
turbo_j
Jun 13, 2003 11:26 PM
