Replacing less than 4 tires on STi?
Old Apr 1, 2005 | 01:14 PM
STiPilot's Avatar
Car Info: '10 WRB STi SE / '09 BMW K1300S
I know it's recommended to replace tires in full sets. But I have about 40% left on my tires and I just ran over a very large screw that's a little too big to plug.
Think I can just replace 2 tires on my 04 STi?
Jason
Old Apr 1, 2005 | 01:37 PM
Kean's Avatar
Car Info: 03 WRX / 08 Forester
How about buying one and having it shaved to the diameter of the others?
Old Apr 1, 2005 | 01:42 PM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
I'd love to hear Subaru's official answer on this. You should contact them and see what they say.
I know that with AWD, you are supposed to run the same diameter tires front and rear, with some allowance for wear that occurs over time, being able to run a different diameter mini-spare for several hundred miles, etc. Even air pressure determines the OD, but anyway...
Please contact subaru and get us an "official" answer! (not the opinion of a service manager or something hokey pokey, either!!!)
Old Apr 1, 2005 | 02:13 PM
Kean's Avatar
...the answer should already in the manual. I believe the tolerance is 1/4"
Old Apr 1, 2005 | 02:28 PM
You can grab just one tire (another of the same brand and model of course) and shave it to match the others.
Old Apr 1, 2005 | 03:37 PM
leftwo's Avatar
Car Info: 05 STi
Well, I have the same problem, and I went ahead an replaced just one tire because I don't have enough
extra cash to replace all four. I just got some tax returns and I was thinking I might replace the
one opposite my new one so at least both front tires would be the same, and both back tires would
be the same.
I don't know if I could bring myself to buy a brand new tire, then shave off %60 of it.
Let me know if you find out an official word.
Old Apr 1, 2005 | 04:48 PM
sonic_yellow's Avatar
Car Info: 03' Subaru Impreza WRX - R.I.P.
the official word from Tire Rack:
Subaru - Within 1/4-inch of tire circumference or about 2/32-inch of each other in remaining tread depth.
Here is the informative page where it came from.
http://www.tirerack.com/tires/tirete...chingtires.jsp
be the same.
Old Apr 1, 2005 | 05:15 PM
STiPilot's Avatar
I just got off the phone with Autowest Subaru (Roseville, CA) and the service advisor checked their documentation and they told me that the new tire must be no more than 1 inch larger in circumference than the remaining tires.
I haven't had time to call a central Subaru number yet since I'm at work.
Anyone happen to have the circumference of a new Bridgestone S-03 for the STi size?
I'll keep on trying to get more information.
Thanks all for the information so far! As always, you all are very helpful!!!!!
Jason
Old Apr 1, 2005 | 05:20 PM
Assuming you were on S03s before the incident, all you have to do is order a new tire and find a place to shave it down to the same tread depth as your others. As S03s are molded with 10/32 of tread, I'm quite sure you'll want to match within the 2/32 recommended by Tire Rack. I would. Also, Tire Rack will shave tires for you fairly cheap.
Old Apr 1, 2005 | 05:21 PM
It's a whole lot cheaper than replacing all four, which is the only real alternative.
Old Apr 2, 2005 | 07:55 AM
Lowball's Avatar
Car Info: 02Wag on 17's
yes, this works.
i had a set of BFG KD's (167each) and got a nail in one. couldn't fix it. ordered another one "shaved" from TireRack (Luke). worked fine. just get a tire tread depth gauge and measure all the tires and then have the new one shaved down to either the avg, or close to, of the other three.
Old Apr 3, 2005 | 07:22 PM
STiPilot's Avatar
Thanks for all the input guys!!! Looks like I'll probably just buy one s-03 and get it shaved down.
Jason
wroxsti
Oct 16, 2007 07:44 AM
dSpec
Jul 22, 2007 10:40 PM
sfsuwrestler1
Subaru OEM Parts For Sale
Aug 9, 2006 04:52 AM
Aln
Apr 28, 2004 04:35 PM
huck
Aug 10, 2003 12:36 PM
