Help! 05wagon with ce28n, tire n rim?
Old Jun 8, 2006 | 07:49 PM
kingfai's Avatar
Car Info: wrx wagon
I am new 05 wrx wagon owner. Just going to order the ce28n but not sure about the tire size and offset. It must clear ap 4pots and not rubbing the fender. Which setup is better? Pls help.
225/45/17 8J offset +44
or
225/45/17 8J offset +38
Old Jun 14, 2006 | 03:42 AM
HomerJay's Avatar
Car Info: MY00RS25
Unless you are going to roll your fenders, you need to get an offset closer to +50.
Old Jul 10, 2006 | 03:56 PM
+44 will fit fine if they are 8" wide or less. 8.5" wide will be alignment dependent. You're on your own with brake clearance though, that's a pretty rare combo. The +52mm 17x8.5 CE28 will not clear STi Brembos, even with with 10mm of spacing.
SubaruCoupe
Aug 30, 2004 03:51 PM
Metaxa07
May 2, 2004 01:53 PM
iMPULSZE
Aug 19, 2003 09:19 AM
figowitz
Mar 30, 2003 12:06 PM
NRTmotorsports
Mar 27, 2003 08:59 PM
