Vendor, Tuning, Service, and Parts Review Feel free to discuss vendor experiences but please don't use the forum as your own private soapbox to perpetually bash specific vendors.
Review: Best Bang for the Buck from Buschur Racing
Old 03-20-2008, 02:39 PM
spt
Senior Member
spt's Avatar
Car Info: Proj STI, Evo, JDM 180sx Time Attack, & A3
CLICK HERE TO READ
spt is offline
Old 03-21-2008, 09:45 AM
rmatt8748's Avatar
Car Info: asd
asda
rmatt8748 is offline
Old 03-25-2008, 12:30 PM
subie OCD's Avatar
Car Info: 04 STi
Exhaust and intake with no tuning?
I thought that was bad juju for the ecu and motor
subie OCD is offline
Old 03-25-2008, 12:54 PM
spt
Senior Member
spt's Avatar
I ran a datalog for each run to make sure there was no knock or anything else out of the norm. Getting a specific tune for this setup would be the best way to go just to make sure everything is working correctly.
This review was more about how much the part themselves helped to make power without the aid of a tune. With a retune I would expect to see bigger #'s.
spt is offline
Old 03-25-2008, 01:01 PM
BanHammer™
Max Xevious's Avatar
Car Info: 2001 Forester RS2 SPEC-F
honestly.. I don't think you will see a whole lot of difference with a tune.
on the 05s when we would tune them, you could throw on a Injen cold-air intake and exhaust, and it would lean the car out enough from stock that it was almost making the perfect amount of power for the mods. After a tune, we could only squeeze a bit more out of the car.
out of the box, the 05's ran very fat on the stock map, these mods would lean it out enough to muster a lot of power for just bolting on a few items. I have a feeling that the 06 and 07 were in the same boat.
I believe beyond this step is when tuning is mandatory to achieve the full potential out of the add-ons.
very nice writeup btw
Max Xevious is offline
Old 03-25-2008, 01:16 PM
spt
Senior Member
spt's Avatar
I disagree about the power gains. I think you would see much more torque and some additional hp from the setup. But the only way I can say for sure is to get it retuned and put it back on the same dyno (basically show some proof). Stay tuned for the article.
Also thanks for the article compliment. :RockOn - not mine:
spt is offline
Old 03-25-2008, 01:17 PM
BanHammer™
I would like to see that as I only have the experience on the 05 retunes with the mods. I would like to know if Subaru changed anything from the behavior we had with that model year compared to the 06 and 07.
Old 03-25-2008, 01:25 PM
spt
Senior Member
spt's Avatar
One thing I will mention is getting a new fuel pump to do the retune is ideal. I will probably drop one in to do it. Now on the 05 do you see the lean conditions with a upgraded fuel pump or just a stock unit?
spt is offline
Old 03-25-2008, 01:28 PM
BanHammer™
I would not call it a lean condition, just that the car will run leaner then it was from stock. The stock 05 would run pig rich and very VERY low AFR's. When the cold-air and exhaust was installed, it would lean out the stock map enough to put the AFR's into the range we would like to see.
we tried a Walbro 255 with the stock turbo, but did not see much of a performance difference. The stock injectors were the limiting factor more then the pump was. I am not sure of the 05 injectors are the same as the 06 and 07 and could possibly be a roadblock.
Old 03-25-2008, 01:37 PM
Staff Member
charlesj's Avatar
Car Info: 06 STI
Based on my experience with the car and knowing how the tune sits now, I am very confident it will make a significant improvement. Will be great to document it thoughh
charlesj is offline
Old 03-25-2008, 01:40 PM
spt
Senior Member
spt's Avatar
Okay cool. I agree the stock injectors will be the limiting factor. From my understanding the injector size (535cc) is the same between the 2 years but I could be wrong.
I just want to make sure that if I do use a new fuel pump (255l) and stock injectors and make larger power #'s no one will question it. Dropping in a new fuel pump is fairly cheap and a easy install. I want to do all of this in steps.
spt is offline
Old 03-25-2008, 09:13 PM
chubs22's Avatar
Car Info: '04 STi
non-resonated straight through design, that exhaust must wake up the dead
chubs22 is offline
Old 03-26-2008, 06:42 AM
spt
Senior Member
spt's Avatar
It is loud but Buschur does have other versions that are more quiet. I went with this exhaust because I wanted something more aggressive when the car is on track.
Here's a video to give you an idea of how loud: http://www.youtube.com/watch?v=4rmjeocBkrM
spt is offline
Old 03-26-2008, 12:44 PM
chubs22's Avatar
Car Info: '04 STi
Sure does sound nice!
chubs22 is offline
Unit 91
08-13-2009 01:03 PM
chubs22
05-22-2006 08:21 PM
FoToHo
03-21-2004 01:15 AM
02eugeneRS
22
05-08-2003 12:26 PM
JZa80GTRHybrid
12-28-2002 08:31 PM
Quick Reply: Review: Best Bang for the Buck from Buschur Racing
