Vendor, Tuning, Service, and Parts Review Feel free to discuss vendor experiences but please don't use the forum as your own private soapbox to perpetually bash specific vendors.
EQ Tuning does it again!!!
Old Feb 7, 2011 | 09:50 PM
bpatrick's Avatar
Car Info: 2007 Impreza WRX Limited Bugeye Conversion
Well its a long story but the short of it is, if you want your subaru tuned right go to Ed.
About a year back I had an intake issue. My stock box broke because of the K&N panel filter not fitting right causing lean conditions and cracking a ring in one of my cylinders (confirmed by a leak down test done by EQ at my 60K )...
I got tired of fixing my air box and worrying about damaging my motor further because of that stupid air box. So I needed a new solution, upgrade the air intake to an aftermarket cai, but I would need a retune.
Kinda waste to retune the car for just a cai, so I took the next step an picked up a vf48 and tmic from an 2010 sti and 65mm aps cai. Had EQ Tuning do the install and got to go road tuning with Ed again just after sunset, flying down the country roads with no headlights because the fuse went...
Unfortunately Ed wasn't able to get the full potential out of the new mods because of a boost creep issue probably due to increased flow. So it was either live with boost creep (really bad for the motor with a lead foot) , get a new down pipe that might not solve the problem or find an ewg setup. Of course I went with the with an ewg.
I thought I'd shop around an find a good set up, read a bunch of threads and reviews and decided on IAG Performance's EWG 38mm TiAl V-band set up which I thought would work great. I also had Ed's crew fab up a high flow cross pipe and port the exhaust manifolds.
On install day Ed pulled out the uppipe and laughed, commenting that it looked like some of the junk that came on the no-name brand aftermarket headers. When Ed showed me EQ's slick uppipe I immediately saw the difference. The IAG uppipe was about 2" in diameter with a reducer sleeve and some weird overlaps on the flanges. Although the quality of the welds are good and the fitment was ok, it looked liked it was designed by someone who had no idea what an uppipe was for. I jumped at the chance to own EQ's uppipe when Ed suggested it.
Moral of the story: Have Ed just do everything right.
Nash as always did an amazing job removing and installing the components (with me getting in the way).
Kelly did an awesome job creating a custom dump tube and welding the waste gate shut (yup, no going back!!!)
Once everything was buttoned back up, it was Ed's turn on the dyno. He asked me what I was looking for and knew how to deliver. It was something else to see and hear my engine roar on the dyno and the waste gate scream at 10 psi all the way to 6800 rpm. Not as much fun as the back road tuning but just as exciting.
When all was said and done with low compression on one cylinder:
279 whp @ 5.8k and 304 wtq @ 3.85k at 18.5 psi
Mods:
2010 vf 48 with tmic
EQ ported exhaust manifolds
EQ high flow cross pipe
EQ uppipe with TiAl MVS 38mm EWG and EQ custom dumptube
Crucial Racing Shorty Downpipe and race pipe
HKS Carbon-Ti Catback
APS 65mm CAI with Amsoil Filter
Perrin Turbo Inlet and Afta MAF
EQ Smog pump delete
255lpg fuel pump
Stock injectors
Thanks again to everyone at EQ Tuning: Ed, Sonya, Brendan, Nash, Kelly and Dallas for providing excellent customer service, parts and tuning. I'll be back when it's time for a new motor (hopefully not too soon!).
Sorry for the crappy cell pics...
EQ Tuning WRX Cross Pipe
EQ Tuning (right) vs IAG Up Pipe (left)
Before porting...
...after porting!
Welded waste gate, TiAl EWG and EQ Tuning custom dumptube
On the dyno
Old Feb 7, 2011 | 10:35 PM
Static Fitment's Avatar
Car Info: E85 Tuned
Nicee to see you got the car on the right track. EQ ftw!
Old Feb 8, 2011 | 09:43 AM
apetron's Avatar
Your car sounded so good on the dyno. I was tucked in the backseat working on my harnesses and then all of a sudden I hear waste gate.
Good stuff indeed!
Old Feb 8, 2011 | 10:08 AM
SeaOfGreen's Avatar
Car Info: 2004 WW Evo RS
Boost creep issues? Why would you need EWG, you should not need EWG on a small turbo like that! Maybe Ed can say why.......
Old Feb 8, 2011 | 11:07 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Thanks for the kind words Bobby! I'll see if I can dig up your dyno chart later today.
-- Ed
Old Feb 8, 2011 | 11:10 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Some combinations of intakes, downpipes, and exhausts can cause boost creep with VF turbos. Its actually much more common to see boost creep on smaller turbos rather than larger. In this case, the car had a very free flowing intake setup, free flowing exhaust, and a divorced wastegate downpipe that restricted the wastegate flow a bit too much. When trying to run wastegate boost on this car, we would see boost go over 20psi due to mechanical creep. The option was to try to a different downpipe, port the wastegate, or just switch to EWG. Bobby chose the latter.
-- Ed
Old Feb 8, 2011 | 10:47 PM
bpatrick's Avatar
-- Ed
EQ Tuning is the best motorsports shop I've had the fortune of stumbling into. You have created a wonderful place for car enthusiasts to learn about and bring about the best potential of their cars. I appreciate your efforts and want to share it with those who are equally passionate about their subarus.
I definitely would like an electronic copy. Thanks
Old Feb 8, 2011 | 10:50 PM
bpatrick's Avatar
Good stuff indeed!
Definitely! The sound was deafening in the back when the ewg kicked in. It just roars on the road. I'm having a hard time trying not to kick in the ewg every time I get on the freeway!
Old Feb 9, 2011 | 01:10 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Here's your dyno chart Bobby:
-- Ed
Old Feb 9, 2011 | 02:11 PM
LOL_VTEC's Avatar
Car Info: 2018 Tacoma TRD PRO
Always nice to see a good write up!
EQ is the place to go, period. I'll see if I can do a nice write up too
Old Feb 10, 2011 | 08:04 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
We'll definitely have to post your results... Should be fun!
-- Ed
Old Feb 15, 2011 | 10:31 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Your motor is all ready and being dropped in right now
-- Ed
Old Feb 15, 2011 | 10:38 AM
LOL_VTEC's Avatar
-- Ed
Old Feb 15, 2011 | 10:47 AM
bpatrick's Avatar
-- Ed
Definitely jealous... Just wait until its time for my rebuild...
Old Feb 17, 2011 | 07:19 PM
SK's Avatar
SK
Car Info: an EQ tuned box
............*snip*
Yup.
Bummer about the cracked ring (a legit reason to kick it in high gear & put in the works), though not at all surprising: Ed delivers.
Regardless of popular census - proven numbers/power don't lie. EQ is no joke. Look it up if anyone doubts.
Again, sorry to hear about the deteriorating component, but congrats for landing at the right shop. Ed suffers from OCD (insisted that I didn't leave after 6 + hours before ironing out quirks) and that's a good thing for guys like us. Perhaps I'll get to check out the ride at one of the EQ BBQs.
Good luck with the endeavor and keep us posted.
Top
