Gauging Interest AEM EMS
Well due to my limited capabilities in tuning I am thinking of selling my AEM EMS or trading for a Cobb Street tuner (05 WRX) , I need somehting a little more simple to learn with.
Included
AEM EMS - Firmware Updated @ AEM to latest (02-05 WRX)
AEM Software (CD)
AEM Instructions (CD)
GM Boost Control Solenoid (Much better than factory)
Extra ECU Pins about 5 I think
PM Me with offers or questions!
Included
AEM Software (CD)
i have a LINK 44-s ecu...cost me 1399 at the time...check out Gruppe -s...they have it there for 999
IF interested email me at boostedblue@yahoo.com
thanks
Link Plus/Link 2
link-electro.co.nz
Is there a Subaru user base available for this ECU? If so, where?
Yes, spread among the i-Club.
An estimate of the ECU's pricing?
~$1300
Is the ECU programmable by laptop, handheld controller, or both?
Both.
Does the ECU function in a "stand-alone" or "piggyback" fashion?
Stand-alone.
Is the ECU delivered as a "kit", or a "plug and play" package? For what models?
Yes. All 2.5RS's, and WRX models are supported through plug and play units from AMR.
What datalogging capabilities does the ECU have?
To laptop hard drive or onboard memory.
Does the ECU have the ability to control boost pressure?
YES
Does the ECU allow for maps to be switched on the fly, and will it need to be "reset" before the map will take effect?
Yes, it can be switched on the fly, without a reset.
Does the ECU have any sort of knock correction feedback?
YES, programmable.
What type of correction factors (coolant temp, air temp, etc) does the ECU use?
Coolant temp., Intake Air temp., Barometric Pressure
What oxygen sensors does the ECU unit utilize?
Narow-band.
Will the ECU drive low or high impedance injectors? Both impedance types?
Both. High impedence injectors can be driven directly, but low impedence injectors need ballasts.
Will the ECU drive an additional 4 injectors (8 injector staged setup)?
Unsure- can fire 8 injectors, looks like you could fire to fire 2 injector per cylinder, but not only have one kick in at a higher pressure. 2 additional drive can be configured to rpm or %ff
What load references can the ECU use for tuning purposes?
MAP, TPS, and MAP+TPS
What resolution does the ECU offer in tuning (how many load points, RPM points, and what increments of adjustment)?
200 zones
20 0-10000RPM in 500 rpm increments
10 0-300kpa (29psi boost) in 30 kpa increments.
Linear interpolation between points.
Non adjustable unit scale
Does the ECU have the ability to drive external hardware? If so, how many, and what type?
Yes, 2 additional devices.
Will the ECU run off of the stock crank position sensor? Or will one need to be fabricated?
Runs off stock unit
thanks
Link Plus/Link 2
link-electro.co.nz
~$1300
Both.
Stand-alone.
YES
YES, programmable.
Narow-band.
200 zones
Runs off stock unit
Bump Pictures
Not pictured is GM BCS and ECU Pins (4 Pins New)
http://www.russellhenry.cihost.com/AEM/
Pm me, I am willing to take a small loss on this to get rid of it. This EMS goes for over $1400 on ebay + shipping.
perfection moto
Vendor Group Buys/Specials
Apr 14, 2005 11:49 AM
