popping noise?
Old Jun 28, 2012 | 04:44 PM
Bigpat57's Avatar
Car Info: 2005 subaru LGT
popping noise?
i here a poping noise sometimes when i turn hard right or pull into a drive way not lowered yet but i have perrin sways. any thoughts?
Old Jul 10, 2012 | 10:08 PM
wongjonsilver's Avatar
Car Info: 2011 WRX base - SWP
Depending on whether it is coming from the front/rear of the car, it can be multiple things.
1) It's your sway bar bolt moving against the slot in the rear subframe. You most likely didn't torque it down enough. Every time you are shifting the weight of the car, the bolt shifts up and down.
2) There is play between the endlink inner diameter and the sway bar bolts
Just check to make sure everything it torqued down. Sometimes re-torquing of hardware is necessary after an initial break-in period.
1tyme
Jan 1, 2005 11:45 AM
EvilTaco
Sep 7, 2004 07:10 PM
osidescooby
Dec 22, 2003 10:52 AM
catdogr
Aug 14, 2003 08:29 AM
JUNNEL20
13
Jul 1, 2003 04:02 AM
