Will WRX brakes fit my non-turbo?
Old 11-10-2006, 01:06 AM
impreza4touge's Avatar
Car Info: 2006 Impreza 2.5i Sportwagon
Exclamation Will WRX brakes fit my non-turbo?
Hi,
I have a 2006 Impreza Sportwagon. I have friend offering me OEM WRX front brakes to me. If I can mount those, what mods are necessary?
Thanks in advance.
impreza4touge is offline
Old 11-10-2006, 07:59 AM
mrruins's Avatar
Car Info: 05 toyota tacoma
The Wrx brakes can be used on your Sportswagon. What year Wrx brakes are you getting? Make sure you are getting both the rotor and calipers.
Extra info.
Early 02 Wrx brakes use different pads. MY03-05 Wrx brakes use same pads. MY06 Wrx used 4-pot brake pads.
mrruins is offline
Old 11-10-2006, 04:18 PM
wagonrex's Avatar
Make sure u have both the rotors and calipers from the wrx then u will be good to go .
wagonrex is offline
Old 11-11-2006, 12:30 AM
Smile Thanx!
Thank you for those tips. I'm eager to get this going so I'll be ready for HPDE at Thunderhill in spring.
Cheers
Old 03-02-2007, 12:04 AM
subimonkey's Avatar
Car Info: RS
How about 02 RS? Can I mount the Brembo rotor and caliper from the STi onto the RS? I heard there's an extension bracket in order to get the 4-piston calipers to work (Brembo or Subaru OEM), is that true?
subimonkey is offline
Old 03-03-2007, 08:06 PM
sirhankwilliams's Avatar
Car Info: 08 STI
Here's what I've done for brakes on my '02 WRX wagon that I HPDE (& RallyX) around N.CA:
•STi master brake cylinder
•StopTech braided lines
•Racing Brake 'H6' rear conversion: (this might be what you're thinking of)
http://www.racingbrake.com/IMPREZA_R...2071-111-0.htm
•Racing Brake 'Big Brake Kit' 4-Pot Aluminum Calipers (that uses stock size rotors)
http://www.racingbrake.com/WRX_FRONT...111-411-78.htm
•AP Racing 551 Brake Fluid
•Hawk HP+ Brake Pads
My car now stops like a mo'fo, although thanks to the HP+ pads, it also squeels like a little schoolgirl. :wiggle:
sirhankwilliams is offline
dub81
11-21-2007 11:20 AM
AMS
07-27-2007 09:10 AM
subaruferrucci
03-28-2007 06:15 PM
suby_dude
Vendor Group Buys/Specials
08-23-2004 12:59 PM
Quick Reply: Will WRX brakes fit my non-turbo?
