will there be a difference?
Old Feb 29, 2004 | 03:38 AM
whitelegacy98's Avatar
I am planning on getting stainless steel brake lines and better pads this summer and am curious, how much improvement can I expect? will it even be notable?
Old Feb 29, 2004 | 11:14 AM
Uncle Scotty's Avatar
Do it and let us know....
Old Mar 1, 2004 | 08:28 AM
ish's Avatar
ish
yes you will notice a big difference. the stainless steel lines increase responsivness in the brake pedal. and better pads will definatly help you stop faster
i just upgraded my rotors, pads, and lines and the difference is incredible over stock.
i also had a few friends put ss lines on there cars without changing anything else and they noticed quite a difference right away as well. that was on a 2.5rs and a sti
Old Mar 6, 2004 | 10:56 PM
redrex's Avatar
Car Info: was 05 WRX Wagon
Don't forget to upgrade your brake fluid as well. Good brake fluid like Motul RBF 600 holds up real well, especially under hard braking.
-Soren
Old Mar 12, 2004 | 12:47 AM
ommmjido's Avatar
honestly i didnt feel much of a difference when i got mine. but thats only for street driving, havent try them on the track yet.
Old Mar 12, 2004 | 01:29 AM
Daredevil's Avatar
i can't wait to see what the difference is
Old Mar 16, 2004 | 08:43 AM
gentyle's Avatar
Car Info: 02 WRX
front lines only?
to piggy-back, does anybody know whether or not it's kosher to just replace the front lines with s/s and leave the rear stock? somebody had told me a while back that if you're gonna change the lines, you should change all 4. opinions?
Old Mar 16, 2004 | 11:41 AM
Wrxneffect's Avatar
Car Info: 03 Wrx black sedan + 2013 BRZ
Why would you want to just change the front? If it's money I think one should just save up for all 4 and do them all. Nothing to base that on, I just like to have my stuff match.
Jason
Old Mar 16, 2004 | 04:34 PM
Magish's Avatar
Especally with the pads you will feel a vast improvement in Braking power and strength. Havn't done the lines so I couldnt tell you that one.
Cheers
-Jeff
Old Mar 16, 2004 | 04:49 PM
GarySheehan's Avatar
Car Info: 2005 Subaru STI
If you just replace the front lines, the rear rubber lines will still flex under pressure, so you will improve pedal feel slightly, but it won't be as good as if you did all four lines.
Gary
Sheehan Motor Racing
www.teamsmr.com
haji
Feb 17, 2004 10:17 AM
WRX lova
Feb 4, 2004 04:00 PM
Sea Dragon Rex
Oct 6, 2003 03:13 PM
mini_wrx_owner
May 7, 2003 01:56 PM
vadim
Dec 28, 2002 09:45 AM
