Whiteline HD swaybar mounts, any problems?
Old Aug 21, 2003 | 12:11 PM
syncopation's Avatar
Car Info: 2003 WRX Wgn
Hey gang,
Anyone have any trouble with there Whiteline rear HD swaybar mounts?
I heard a clunking in my rear suspension this morning. Closer inspection revealed a broken HD mount on the right side. It fractured along the "L" bend close to the bolt. This setup also had the whiteline bar and HD endlinks.
The funny thing is I have yet to take my wagon to the track! It was basically broken with some moderate canyon carving.
It's possible I have a defective part. I'm going to check with mastro about a replacement, and when I get in tonight I'll try and post a pic.
Old Aug 22, 2003 | 03:05 PM
Wow, that's strange. What size bar are you running? Contact Whiteline about it and email Jim Gurieff, his email is posted on the site.
Old Aug 22, 2003 | 08:08 PM
Pictures as promised,
I'm running the adjustable bar set to middle hole (22mm). I was gonna post over on MRT's Whiteline forum for Jim, but I wanted to see if anyone else had similar problems.
Old Aug 22, 2003 | 08:34 PM
I'll try again!
Attached Thumbnails Whiteline HD swaybar mounts, any problems?-103-0333_img.jpg
Old Aug 22, 2003 | 08:38 PM
one more..
Attached Thumbnails Whiteline HD swaybar mounts, any problems?-103-0331_img.jpg
Old Aug 22, 2003 | 08:44 PM
I just wanted to add that I don't believe this broken mount is representative of Whiteline products. I do not want to deter anyone from buying their great stuff!
Old Sep 1, 2003 | 12:17 AM
Uncle Scotty's Avatar
Originally posted by Whiteline
Hi everyone,
My, that is a first. I'm not really sure what happened as that side is usually not that stressed. It could well be a manufacturing fault but either way we will replace straight away (including the other side).
DavideWRX might be right about the cause but please let me know if you have any problems and we will handle it from here.
Cheers
Jim Gurieff
Whiteline
This is a perfect example of why a good bit of my suspention mods are Whiteline products.
Thanks, Jim.
Old Sep 7, 2003 | 09:46 PM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
Dang... no way in heck would I buy these now.
Old Sep 13, 2003 | 02:50 AM
Didn't you read the whole thread?
Old Sep 13, 2003 | 11:27 PM
He forgot this:
[/sarcasm]
Old Sep 14, 2003 | 04:37 PM
FIREX's Avatar
Car Info: 02 WRX SEDAN
I have Whiteline H/D swaybar mount with a Cusco 22mm bar and Perrin endlinks. I had MRT endlinks at first and they seemed to make to much noise,I installed the Perrin's no noise. The only problem I had with the Whiteline H/D mount kit was the bushings they only sent me one ea. 22mm, one ea. 20mm and two ea. 24mm. I was noticing some shifting of my swaybar laterally and the bushings are coming out of the mounts. I just installed some Energy Suspension greaseable sway bar bushings 22mm there nice and this has stopped all noise but still have a little shifting next will be Perrin antishift kit. .
SpeeDyScooBy
25
May 1, 2008 09:26 PM
grex767
May 27, 2006 10:37 AM
Speed Element
Engine and Drivetrain
May 3, 2006 11:03 AM
WeRX4Me
Feb 3, 2003 07:09 AM
