teins 1-way 2-way adjustable whats the difference
Old Aug 16, 2003 | 10:39 PM
SS has only bound or rebound adjustment (not sure which it is) and the Flex has both bound and rebound adjustment.
Old Aug 17, 2003 | 12:49 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
1 way means that the compression and rebound are adjusted together. Basically you have X present for rebound/compression combination settings.
2 way means that you can adjust compression and rebound INDIVIDUALLY.
HOWEVER,
Sometimes, people misadvertise and refer to "2-way" adjustable coilovers as to 1-way + height adjustable.
Old Aug 17, 2003 | 11:34 PM
From the sound of things, it means that one can only be used to lower the car, while the other can actually raise the ride height from stock.
Old Aug 18, 2003 | 12:51 PM
samowrx's Avatar
Car Info: 2002 WRX Wagon
i always thought 2-way had threads above and below the spring. that way you can adjust the spring preload while still getting the proper strut travel.
cuscoWRX
Jun 3, 2004 11:47 PM
gordy
Dec 2, 2003 01:07 AM
WRX lova
Oct 15, 2003 08:54 PM
OakosAutomotive
Vendor Group Buys/Specials
Jan 9, 2003 02:08 PM
