Tein S-Tech - bump stop cuts required?
Old Apr 20, 2004 | 06:11 AM
DJ Catchem's Avatar
Car Info: '02 WRX sedan
Hey all. My suspension components are arriving bit by bit this week. (S-Techs showed up this morning, AGXs, Progress RSB and endlinks are not far behind...) I was going through the Tein instructions this morning, and it made mention of the bump stops, and said that it might be necessary to trim them for the install. I checked out the accompanying chart, and for the '02 Sedan, it says:
FRONT:
Cut type = A
inches = 0.6
REAR:
Cut type = A
inches = 1.6
Now, I'm assuming that this means I trim those measurements off the bumpstops. (Please correct me if I'm wrong.) Does any one know what the "cut type" refers to? There's a note on the bottom of the sheet that states, "Refer to the figures shown in the instruction manual for Cut Types." Of course, there's nothing in the manual about it...=)
Anyone have experience here?
Old Apr 20, 2004 | 08:38 AM
DizzyWRX's Avatar
I installed my S-techs and didn't have to cut anything. I have no problems whatsoever with my suspension.
Old Apr 20, 2004 | 11:14 AM
DJ Catchem's Avatar
Strange. You have an '02 as well? I will be installing the AGXs at the same time, so a stiffer shock will help stay clear of the bumpstops anyway, but it's still recommending to trim over an inch and a half from the back. I don't know...
Old Apr 20, 2004 | 11:30 PM
Uncle Scotty's Avatar
I just hope you don't hate the s-tech springs....many who install them have....
Old Apr 21, 2004 | 06:54 AM
DJ Catchem's Avatar
Well, it's not an expensive set of springs, so i'm not out all that much if they don't work for me. I like the drop, so it's a good place to start. Since I won't ever have this car on a track or strip either, I'm not too worried.
Worse comes to worse, I'll swap springs out for a different set.
Of course, I'd rather not cut the bump-stops on this install for that reason...=)
Old Apr 22, 2004 | 12:09 PM
DizzyWRX's Avatar
I actually have an 04. And i love the s-techs! Perfect height, and soft too so it is still a comfortable ride. My struts might hate them...
Khooda
Jan 19, 2006 11:26 PM
jc5d5d
Feb 1, 2005 10:06 PM
Haole-Pino
Dec 1, 2004 03:49 AM
ryeoj2003
Aug 13, 2004 09:04 PM
t-wrexxx
Mar 14, 2004 07:39 AM
