tein flex rear camber plates?
Old Dec 30, 2009 | 01:23 AM
SOHI's Avatar
Car Info: 2005 STI, 2009 XT
alright i have an 05 sti, i am running tein flex coilovers and am in need of a rear camber plate. i am running 18x9 by 30 rims and need to pull the top of the tire in for more clearence. i have bolts and all 4 whiteline adjustable control arms. with the arms i have to run 3 degrees to clear due to them pushing out the bottom of the tire and not pulling in the tops. i contacted tein and they can rebuild the flex's to fix there plates they make for the mono flexs= stupid money and down time. so does any one know a rear plate i can run with the teins? if not i am thinking about running the bc racing er coilovers with plates. any help would be great, thanks guys
Old Dec 30, 2009 | 06:47 AM
sick EJ20's Avatar
Car Info: 03 bug eye
I'm actually on the same boat as you. Try calling turn in concept, i think they said the vorslag's work. let me know if you figure out something.
Old Dec 30, 2009 | 11:46 AM
SOHI's Avatar
400 for plates ouch, left a voice mail with turn in. Keep u posted
Old Dec 30, 2009 | 12:25 PM
SOHI's Avatar
Turn in told me unsure of fitment, would have to pull coilover aparts and measure shaft width height......, there has to be some one out there that has a for sure answer
Old Mar 24, 2013 | 10:32 PM
(V)aniac's Avatar
Car Info: WRX STi '06 with extra stuff
TEIN Flex CO's and Camber Plates
Same exact issue...did any of you figure out if the TIC Vorslag's work? Please let me know before I throw my Flex CO's in the ocean.
Old Apr 6, 2013 | 09:59 PM
(V)aniac's Avatar
Eibach Camber bolts and grind...
Thought I would share what I engineered to get 18x9.5 e38 ROTA Grids with 245/40/18r's to work on my 2006 STI without rubbing. I have TEIN Flex Coilovers and needed the Eiback Camber bolts to add camber in the rear as the Flexes have no camber plates.
- Grinded the rear fender lips using an angle grinder
- Eibach camber bolts (provided -1.75*...moved wheel about 8-9mm in)
- Rolled the front fenders
- 5mm spacers up front (consider using 8mm-10mm spacer as they are very close to calipers)
No more rubbingHere is a photo:
https://www.i-club.com/forums/attach...y-img_0347-jpg
Old Apr 7, 2013 | 11:10 PM
Heedz's Avatar
Nobody likes the tuna here
I don't get it..
I fit the same size tire on 8.5's with no issues of having to create something to have more camber to fit better...
Old Apr 10, 2013 | 10:28 AM
apetron's Avatar
These are an inch wider and have an effective offset of +33 because of needing the 5mm spacers to clear the brakes. Bit different then your setup Heedz.
The Cusco rear camber plates have been confirmed to fit the TEIN Flex coils. You may need to request a different size center pin (thing that goes into the pillow mount) and top bolt for the plates though. Either way they will work.
(V)aniac
Mar 24, 2013 10:51 PM
ds baruuuuu
Hawaii Classifieds
Sep 29, 2011 04:00 PM
ScoobyWho?
Hawaii Classifieds
Oct 8, 2008 03:31 AM
EJ20PWR
Feb 19, 2008 12:13 PM
thesnowboarder
Oct 17, 2007 09:08 PM
