Tapping sound coming from rear struts?
Old Mar 2, 2010 | 09:23 AM
subbiedood's Avatar
Car Info: 02wrx
So I just installed some kyb-agx struts and Cobb springs on my 02 Wrx. But when the road gets bumpy there's like a tapping sound coming from the rear. It sounds like it's coming from the top hat area. I double checked and everything is tight on top. You guys have any ideas what the problem might be
Old Mar 2, 2010 | 09:27 AM
Jin's Avatar
Jin
Car Info: 05 CGM STi to be converted to RS
i had the same problem, did everything to get rid of it but it just wouldn't go away. so i switched to coilovers
Old Mar 2, 2010 | 10:34 AM
chrisjobe's Avatar
Car Info: 1995 impreza coupe
deffenite Tapping or possibly clicking? If its tapping then i would look for coil bind
(wear/dulling of the paint between coils is the easiest way to tell)
then look at your sway bar. It angle changed when you lowered the car so there could be a bind or interferece.
If its clicking then i would suspect a worn CV axle. and the change of ride height/CV angle could have triggered it to wear more rapidly.
Old Mar 2, 2010 | 01:59 PM
subbiedood's Avatar
Car Info: 02wrx
It's more like tapping. It sounds like it's coming from where the top had bolts up to the car. Idk I think I'm gonna take them off and double check.
Old Mar 2, 2010 | 02:04 PM
tony1w's Avatar
Car Info: 03 Bugeye, D675, Lightning
i have that same noise. it sounds like top hats too... have been too lazy to look. More like a thud type of tap... at low speeds over bumps.
Old Mar 3, 2010 | 12:58 PM
subbiedood's Avatar
Car Info: 02wrx
It's really annoying haha. Someone help me
Old Mar 5, 2010 | 11:02 AM
4Subaru's Avatar
Car Info: 2004 WRX Silver
I had the same issue, there are spacers I bought and they fixed the problem. Here is the link: http://turninconcepts.com/product_in...roducts_id=234
sypher66
Jun 2, 2009 04:21 PM
bluebiker
Dec 21, 2005 03:22 PM
y2Ldude
Oct 16, 2005 09:51 PM
aussiebrydon
Feb 9, 2005 10:14 AM
iNfEk
Jan 17, 2003 10:40 AM
