stock brake fluid?
Old Dec 30, 2003 | 04:16 PM
DrD's Avatar
DrD
Car Info: 2012 Legacy 2.5GT-L
I though the big problem with a silicone based dot 5 fluid was the incompatability with water - rather than the fluid taking on water (i.e., the two mixing together like a normal dot 3 or 4, causing the fluid to get dark colored and the boiling point to drop) the water tends to pool - resulting in increased corrosion, plus a portion of the hydraulic system filled with a fluid which generally becomes gaseous (i.e., steam) at brake operating temps.
I was under the impression that the Dot 5.1 fluids, which are non-silicone, addressed this issue and could be used in pretty much any brake system without fear of the silicone/water problem...
Old Dec 31, 2003 | 10:06 AM
Uncle Scotty's Avatar
See:
http://www.team.net/sol/tech/dot5.html
To get info on DOT 5 fluids.
JMeltzer4
Aug 17, 2010 07:23 PM
RavSpec
Apr 15, 2006 09:13 AM
mbquarts
Nov 2, 2005 03:22 PM
StopTech
Sep 3, 2003 01:32 PM
