STi Suspension Problem (Video Inside)
Old Jan 1, 2004 | 11:53 AM
david2z4's Avatar
From: Washington State, Car: 2000 Impreza Coupe RS-T T
Car Info: 2000 Impreza Coupe RS-T Tec3/Vishnu turbo Color: B
There is the main strut rod center bolt under the housing.
Sounds like it is loose. It is normally the one that gets loose not the three strut top bolts
Old Jan 1, 2004 | 11:57 AM
david2z4's Avatar
Yes with the car on the ground take the three housing bolts off. then you can tighten the center one. Don't go too tight or you can strip it. you might need a allan wrench with a through socket if the strut rod spins when tightening. or a low power impact.
think it is only like 20 lbs torque though.
brucelee
Aug 3, 2009 09:56 AM
yoshi8me
Jan 23, 2008 09:53 AM
EQ Tuning
Apr 24, 2007 01:34 AM
SONofSAM
Oct 11, 2003 11:27 AM
