STi Suspension Problem (Video Inside)
Hey guys.
my driver's side rear strut is making this noise... i cant figure out how to fix it ... as i push/pull on the strut i can feel it moving slightly, can something bu tighten under the 3 bolt housing behing the rear seat ?...
any help would be really apreciated.
btw... the other side doesnt do this
check the video :
CLICK FOR VIDEO (right click save as)
check the video :
From: Washington State, Car: 2000 Impreza Coupe RS-T T
Car Info: 2000 Impreza Coupe RS-T Tec3/Vishnu turbo Color: B
There is the main strut rod center bolt under the housing.
Sounds like it is loose. It is normally the one that gets loose not the three strut top bolts
Yes with the car on the ground take the three housing bolts off. then you can tighten the center one. Don't go too tight or you can strip it. you might need a allan wrench with a through socket if the strut rod spins when tightening. or a low power impact.
think it is only like 20 lbs torque though.
EQ Tuning
Apr 24, 2007 01:34 AM
